![]() | Home > Technical (L322) > Calibrating transfercase clutch etc |
GustavW Member Since: 26 May 2021 Location: Kalmar Posts: 42 ![]() ![]() |
I also do an oil change every 10 000km and keep the car very well serviced. The engine is a smooth as can be, no vibration really when the hood is up.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
I had this on my L405 but it was consistent turning both directions. Double flushed and calibrated the transfer case three times (ie. six times fluid change in total!) and after each double flush it was fine for a couple of weeks then the problem would return. I spoke to two independent specialists who recommended replacing the transfer case (£££). In the end, I took a punt and put a sachet of Dr. Tranny Instant Shudder Fix in - no more judder and has been absoluely fine for at least 5k miles since |
Thanks for the tip!
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 293 ![]() ![]() ![]() |
In the transfer box or in the gear box ? TDV8 4.4 2012 |
Transfer box. It has a wet multiplate clutch so the effect is the same. Kev
Tried the Lubegard today, problem just about solved. Recommended! again, thanks for the tip Fuji White 2011, 4.4 TDV8 Vogue SE |
I have the ETM diff in the back, I believe this also has a multi-plate clutch assembly (locking diff) - I have filled this with the Castrol SAF CARBON MOD PLUS.
Glad it worked for you Gustav |
Mac35 Member Since: 26 Dec 2023 Location: Angus Posts: 13 ![]() ![]() |
I did a single oil change and clutch recalibration the other day and still getting some slight intermittent judder. I’ll have to do another drain and refill and see if it improves. I’m assuming the transfer case is similar to the locking rear diff and has a clutch pack in it. So would it actually be advisable to use friction modifiers as a solution?
I was going to, but my transfer case already had the latest software on it so GAP refunded my money.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 760 ![]() ![]() |
I had the same issue with mine over a year ago - I did a single oil change and recalibrated the clutch and had to drive it for a couple days before I could do the second change. I was disappointed that the single change didn't improve the problem as I couldn't see how 2 changes would fix it if 1 didn't. I was wrong, did the second change and the problem was sorted. I would do the second change before trying anything else. |
The first change has made an improvement so I’ll order some more oil today and do a second change. Thanks for the heads up. |
DennisF Member Since: 07 Apr 2024 Location: 9739085998 Posts: 1 ![]() ![]() ![]() |
You put the Lubegaurd in the rear diff just added 2oz or did a fluid change and 2oz? |
