![]() | Home > My Range Rover > 2012 Range Rover Westminster TDV8 4.4 Fuji |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 221 ![]() ![]() ![]() |
Encountered my first problem with the car, I jumped in it after a few days and got this error on the screen
With the Gap IID tool still on my shopping list, I popped the car on my Ctek charger to boost the battery and after checking with the engine running it was showing 14V via the “secret” menu on the infotainment screen. Phew! Hope the alternator is OK then. I drove it to a friend with some diagnostic equipment locally,. cleared the fault codes and the error disappeared. Noting some of the codes down (there was obviously a lot of them being a Land Rover ![]() Drove the car home and it was fine for a day or two. Then the alarm would randomly be triggered, for no reason at all. A check online showed bonnet sensor to be the issue. It was hot and seemed a common thread with these. Ordered one from Land Rover(revision: longer switch pole) and swapped it over, didn’t fix the issue sadly, but that’s one preventative item done. Bonus point was I had same issue with my E46 M3, I had disconnected the sensor to prevent accidental alarms and discovered the sensor was identical to the one out of the M3, so simply plugged the old one into the BMW and it’s worked fine ever since. This then went on for weeks, trying to find a garage to take it in as my guy was booked up. Eventually it went in and the car was throwing error codes for door locks, giving this the cause for alarm triggers. In true LR/RR fashion, this ultimately was all down to battery issues!! Incorrectly specced Lead Acid item removed, correct AGM item installed. The fault was traced (with the help of a thread on here) to a fault negative cable, containing the BMS which had corroded and gone bonkers. Genuine BMS ordered from Land Rover and installed. Problem solved. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Did you replace all of them? There is one "top left" that is often missed and it's part of an alloy casting, LR022810 (Note that LR024791 is a pulley that also bolts to this casting). The bearing that was shot on mine is part of the "bit" with 3 holes (technical speak) in it ![]() https://www.advancedfactors.co.uk/auxiliar...1791-c.asp Image: https://britcar.com/product.php/175919/549...er_d5_l322 Once that was replaced my squeak went and I sometimes (rarely) get a squeak now but usually on a damp day (damp belt I reckon). Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Did you try Glenrands nr Liphook? Loan cars/collection service. I've used a lot of places in Hants/Berks and won't go anywhere else now. Give Ross a call and tell him I sent you next time ![]() www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Interesting thanks DrRob, will keep in mind.
Missed the other post - I am 90% sure everything was replaced, but I will have to dig out the receipt to double check, it was reassuringly expensive as to be expected |
Forgot to add the pics and bonnet sensor comparison showing the larger post on the revised part.
I use the secret menu sometimes to have the rear camera "on" all the time as I drive along if there is something behind I'm not happy about... |
Thought I would check the maf sensor on the donut, had heard they get covered in crap. Mine was gross and after cleaning this had improved low speed response from the engine/throttle.
As many others have done I fancied some of the chrome arm rest adjusters. Got some from AliExpress and was surprised at the quality having never ordered anything before. Before:
After:
Just adds that little bit of an accent, surprised these were the same as the P38 ones my dad had on his 20 years ago, thought it let the interior down a little. |
Brake Refurbishment
Brakes arrived (second attempt) Gloss black, with standard decals.
Decided to go with LR discs which were surprising value, courtesy of Robin at Duckworths. Pads were a crazy price so decided to get some Green Stuff SUV pads given their use of quality backing plates and positive experience with the yellows on my M3.
Fitting ![]() All done (I also had rear pads swapped to green stuff to match as were bargain bin Brembo jobs from ECP)
[/b][/i] |
Oil Cooler
Removal of the old unit showed the gaskets had begun to flatten, it had leaked but it wasn’t too bad. So all cleaned up and reassembled. ![]()
I also had the EGR pipe and “donut” plenum cleaned out of all the gunk as I sss different from a lot of low down hesitations. This has 100% cured this. ![]() |
So the final two pieces of the puzzle.
Increasingly hard to find for some reason, I stumbled across a set that had just been refurbished on eBay and took a punt.
Then ordered me some of the Pirelli Scorpion Zero PCNS that seem to be so highly praised.
All fitted, I am over the moon with how good it looks. The drive had significantly improved as well, the overall car feeling much lighter. I did not experience a night/day revelation with ride quality as I had expected. But it’s great all round.
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Cars is looking well mate |
Cheers kind sir! It's getting there, still a few jobs to go before I will be happy |
Planned to show the car some love with the DA after a thorough decontamination over the bank holiday weekend. Plans were slightly scuppered due to the ridiculous winds which was blowing a load of crap off my neighbours trees onto the car and into any buckets/mits I was using. Ended up spectacularly running out of time and patience. So ended up just doing a thorough Decon and a small spritz of Turtle wax si02 coating. Tested a few new products - Meguirs wash+ for the roof which is a shampoo with some mild abrasives, rejuvenated the roof!
Next stop was Cornwall! |
