![]() | Home > My Range Rover > 2012 Range Rover Westminster TDV8 4.4 Fuji |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 204 ![]() ![]() ![]() |
Encountered my first problem with the car, I jumped in it after a few days and got this error on the screen
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4311 ![]() ![]() ![]() |
Did you replace all of them? There is one "top left" that is often missed and it's part of an alloy casting, LR022810 (Note that LR024791 is a pulley that also bolts to this casting). The bearing that was shot on mine is part of the "bit" with 3 holes (technical speak) in it ![]() https://www.advancedfactors.co.uk/auxiliar...1791-c.asp Image: https://britcar.com/product.php/175919/549...er_d5_l322 Once that was replaced my squeak went and I sometimes (rarely) get a squeak now but usually on a damp day (damp belt I reckon). Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Did you try Glenrands nr Liphook? Loan cars/collection service. I've used a lot of places in Hants/Berks and won't go anywhere else now. Give Ross a call and tell him I sent you next time ![]() www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Interesting thanks DrRob, will keep in mind.
Missed the other post - I am 90% sure everything was replaced, but I will have to dig out the receipt to double check, it was reassuringly expensive as to be expected |
Forgot to add the pics and bonnet sensor comparison showing the larger post on the revised part.
I use the secret menu sometimes to have the rear camera "on" all the time as I drive along if there is something behind I'm not happy about... |
Thought I would check the maf sensor on the donut, had heard they get covered in crap. Mine was gross and after cleaning this had improved low speed response from the engine/throttle.
Brake Refurbishment
Oil Cooler
So the final two pieces of the puzzle.
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
Cars is looking well mate |
Cheers kind sir! It's getting there, still a few jobs to go before I will be happy |
Planned to show the car some love with the DA after a thorough decontamination over the bank holiday weekend. Plans were slightly scuppered due to the ridiculous winds which was blowing a load of crap off my neighbours trees onto the car and into any buckets/mits I was using. Ended up spectacularly running out of time and patience. So ended up just doing a thorough Decon and a small spritz of Turtle wax si02 coating. Tested a few new products - Meguirs wash+ for the roof which is a shampoo with some mild abrasives, rejuvenated the roof!
