Home > Technical (L322) > how to get into beast when outside latch doesnt work
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Am after some suggestions.
a) changed fob battery some time ago and went to lock/unlock beast...didnt work.
b) tried other key.....same thing,didnt work.
c) put key into slot and turned, it unlocked front door but as soon as I opened it the alarm and 4 way flashers appeared. Put key into ignition and turned to no.1 and alarm/4 ways turn off. TF
d) found where the alarm is and disconnected it, no more alarm but 4 ways operate when I open door. no big deal.
Seeing as I have had problems with the drivers door before (as in outside latch not working), what is the best way to get the transponder working again or putting another lock in the fr passenger door or tailgate so that I could get in.
Have tried to reset key with iid tool and suggestions on here previously and no luck despite repeated attempts.
All suggestions welcome.
thanks
littlecub
Post #663250 2nd May 2023 6:08am
littlecub
Seeing as no-one has replied another question then.
How do I go about getting the keys (original) to unlock as they are supposed to.....dealer?
get new keys cut/programmed $$$$$$$ or do I sell the beast for minimal $$ and go buy something else.
Post #663387 3rd May 2023 9:37pm
Did you see/read this (from the WIKI):
https://www.fullfatrr.com/forum/topic47293.html
Was for a 2002 at the time.... .
Post #663396 3rd May 2023 11:03pm
Have a look at the following fuses. Thumbs Up
Post #663398 4th May 2023 7:55am
littlecub
Thanks for the extra tips guys.
Will let you know how I go.
littlecub
Post #663469 4th May 2023 9:28pm
