![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8352 ![]() ![]() ![]() |
FWIW mine has a new main battery and it is reading 12.21v at the moment having just woken the fatty up to open the bonnet...
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 691 ![]() ![]() |
Unfortunately I don't have a lot of time to reply right now but I did use sdd to tell the car both batteries had been replaced, I've checked the 2 earth's related to power steering (according to an old TSB) both were fine but cleaned them anyway.
IMHO water or moisture in the system will not effect it much...
GaryR Member Since: 30 Jul 2020 Location: Queensland Posts: 16 ![]() ![]() ![]() |
For what it’s worth, I have also seen truck mounted equipment including air pressure switch and air solenoid valve damaged by moisture from truck/lorry air supplies. |
But the amount of air in the system does not effect ride quality, it just determines ride height which is not the OP's issue... Pete
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
The air pressure in the spring affects the spring rate, which very much affects the ride. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1407 ![]() ![]() |
I agree. If you're feeling that suspension is harsh / stiff, its not going to be the air bags or pressure in them. If they were solid enough to affect the harshness, the car would look lifted up ... and it doesn't in this case.
Good shout... |
That is a good shout Fisha and I do recall someone on the L322 thread I had saying he found a bad damper (as his bonnet was shaking up and down on one side of the car when driving) he replaced it and problem solved for him.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i had a buckled wheel on the front off side of mine and it didnt affect the ride...this was found with a road force treatment..they put this wheel on the back for me and tbh i didnt find any difference..
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Well that means that two wheel /tyres are quite a way over the limit set by LR, so that is one positive avenue to investigate.
Yes Merchy it does indeed.
Any ideas what else I can look into here?
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1151 ![]() ![]() ![]() |
I have just made a trip in mine and the only complaint is when the motorway concrete is a little rough or has break lines in it, it causes some rumble otherwise lovely and smooth and comfy. overfinch modified |
