![]() | Home > Technical (L405) > Won’t start |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 800 ![]() ![]() ![]() |
I have the same model and I had the exact same symptoms last year. It’s the auxiliary battery (the small one) that needs to be replaced. It is not monitored and it gives no warning; it’s not expensive and you can do it yourself. It’s under the right panel in the trunk (boot). You don't need any tool for reset after replacement.
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 175 ![]() ![]() |
Where are the two batteries and what are the specs please? 2018 P400e AB LWB |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8513 ![]() ![]() ![]() |
The main one is under the compressor under the spare wheel, the second is behind the cover on the right side of the boot...
No spare wheel for the PHEV, nor can you open up the area under the boot floor 2018 P400e AB LWB |
Oh dear, sorry, can't help then.... does it not say in the Hand Book..?? Pete
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Assuming it has an auxiliary battery and it’s the one causing the issue, as Pete says above, its generally located behind the right hand side boot panel which should pull off with sharp tug - my 5.0 SC needed a new one when the stop/start stopped working, easy job to replace. Jonathan
Of course you can open it! Pull the handle to raise the floor cover, then remove the foam insert with the tire repair kit and admire the 12v battery, the subwoofer and the 14.7kWH Samsung Li-ion battery...
wow! Thanks!
The main battery is 12v 90Ah AGM (absorbed glass mat) and the secondary one is 12v 14Ah (mfd by Exide). For the secondary one, as JCW wrote above, pull the side panel to acces it.
Here's the PDF manual: https://www.fullfatrr.com/gallery/albums/u...Manual.pdf |
Actually, we have three ![]() |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1662 ![]() ![]() ![]() |
@AnnualMan:
Big thanks for all the useful information and suggestions! I’ve ordered the battery tester and also booked the car in at a specialist to give it the once over.
BLT Dave Member Since: 07 Apr 2024 Location: North West Posts: 20 ![]() ![]() |
I had the ‘won’t start’ problem yesterday, though a bit different to any I’ve found in the search
