Home > In Car Electronics (L322) > Bluetooth module and venture cam
Atle TDV8
Norway 2007 Range Rover Vogue SE TDV8 Barolo Black
Hello
I have a 2007 tdv8.
The bluetooth module is bad and it is bypassed. I dont need it for the phone but does it need to work for the venture cam?
I dont want to order new battery for my venture cam if it will not work without the bluetooth module. Very Happy
Post #663086 29th Apr 2023 11:06pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Yes, the venture cam uses the Bluetooth and your phone will disconnect when the venture cam is switched on.
You can replace the old style Bluetooth unit with one from a Discovery (the part number slips my mind) but you’ll need to make a new plug (live and earth only) as the original connector won’t fit.
I hope this helps?
Regards
John
Post #663097 30th Apr 2023 9:30am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
interesting RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #663105 30th Apr 2023 11:08am
Atle TDV8
I hope this helps?
Regards
John
Thank you!
I will source one from a Discovery then.
Post #663110 30th Apr 2023 12:22pm
