Home > Technical (L405) > Won’t start
AnnualMan
Switzerland
Won’t start
Jumped in the car, pressed start, very brief flash of a message about abs or traction control not working (split second so difficult to be sure), then it all shut down. Never got to the stage where the gear knob rose. Tried getting out, locking and unlocking. Same issue. Looks like I’m stranded at home tonight.
Thoughts? 2018 P400e AB LWB
Post #663064 29th Apr 2023 7:23pm
TJH1985
Ours did something similar when the battery got really low on it. Assumed the messages were down to the low voltage. So maybe check the battery voltage? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #663066 29th Apr 2023 7:27pm
pcourtney
one of the main reasons why I have this Hilta 3000 jump pack in the back of my car - only had to use it 3 times in five or six years, but it paid for itself easily many times over Smile
Post #663068 29th Apr 2023 7:39pm
AnnualMan
Switzerland
So it doesn’t give you any warning about low battery first? Just sort of gives up? 2018 P400e AB LWB
Post #663075 29th Apr 2023 8:16pm
TJH1985
Mine didn’t when it was really low no, it did exactly as you describe and when I checked battery voltage was low, after a charge it was absolutely fine. Worth checking IMO
It does when it’s low and needs the engine starting though. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #663078 29th Apr 2023 9:10pm
AnnualMan
Switzerland
Thanks so much for all the advice.
Tried one more time and now the brake pedal judders under my foot.
Plugged in a ctek and it’s telling me it’ll be 6 hours to charge back up, basically proving that the battery isn’t happy.
It’s a late 2018 car so could be on the original battery. I’d have a look but I’m not really sure where it is given it’s the PHEV 2018 P400e AB LWB
Post #663079 29th Apr 2023 9:33pm
Gremlin500
Get one of THESE, and use it regularly with your new replacement battery, Range Rovers eat batteries like you eat a packet of crisps:
£17.61 40% Off | KINGBOLEN BM580 Car Battery Tester 12V 6V CCA Circut Tester Cranking Test Charging Tool BM550 Automotive Battery Analyzer Kw208
https://a.aliexpress.com/_EuiL09N
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663084 29th Apr 2023 10:32pm
Kot
It should give you a warning when your battery is low to "start the engine " doing a lot of shortish runs I always use the ctek every 3-4 months to top it up. It's a 2018 battery as well, so it's soon to be replaced, once I notice its deteriorating.
Regarding the low battery alarm, worth checking the DTC's and clearing them get a cheap BT scanner like Autel AP200 2018 SE SDV8 4.4 Byron Blue
Post #663093 30th Apr 2023 8:40am
It also depends on weather or not the tech switched battery monitoring on in the CCF during the PDI stage... We often find low coolant alarm, low oil level & pressure are all switched off in the CCF menu! Shocked
Post #663100 30th Apr 2023 10:42am
AnnualMan
Switzerland
Just wanted to report that alls well and the ctek seemed to breathe life back into the old girl. Thanks again for all the helpful advice! 2018 P400e AB LWB
Post #663130 30th Apr 2023 5:49pm
Gremlin500
Still worth getting the device I posted, it will confirm the % SOH of your battery, which I suspect will not last much longer, perhaps surprising you when most inconvenient. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663137 30th Apr 2023 6:58pm
AnnualMan
Switzerland
I definitely will, thanks for the tip. Can I measure the battery from the terminals in the engine bay? 2018 P400e AB LWB
Post #663138 30th Apr 2023 8:29pm
Gremlin500
Yes, no problem with that, no need to go into the boot.
I had a few weird electrical issues before replacing my battery last year, and the tool diagnosed my battery was down to 29% capacity! It was basically surviving on the permanently-connected CTEK, but needless to say as soon as Winter arrived problems got much worse.
As I’ve said, FFRR’s eat batteries for breakfast, and 4 years is about the going rate, especially if you have a single-battery vehicle with stop-start, running short journeys. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663142 30th Apr 2023 10:05pm
Gremlin500
I would add that the best jump-pack of all is a decent, healthy main battery in the car itself.
The best way to jump start the car is by pressing the start button, surely? Especially if it’s raining!
I don’t see the point of flogging a “dead horse” battery with another er, battery? why not spend the money on a decent main battery to begin with? Appreciated if you have several infrequently-used vehicles they can make sense.
A good but cheap diagnostic tool will make sure you don’t waste money on a new battery due to other issues. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #663144 30th Apr 2023 10:16pm
AnnualMan
Switzerland
Should I need then install a new battery, would I need a tool to ‘tell’ the car? 2018 P400e AB LWB
Post #663149 30th Apr 2023 11:44pm
