Home > General > few questions re tdv8 |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
Is this a brand new car? If so, get it back to them and say you don't want it. I have heard bad things about Stratstone. Shouldn't be losing height unless you have selected access - best to park in this height anyway. Doors can be programmed to lock on the instrument cluster on 2010+. Follow me home feature is standard and does not need to be programmed. When engine off, simply push main beam stalk away and will stay on for preset time. PS: Update your profile so we can see MY and type of car you have. |
28th May 2011 10:10pm |
Careeraxe Member Since: 12 Dec 2010 Location: Nottm / London Posts: 37 |
yes will update my profile!
28th May 2011 11:46pm |
But sounds like you have no personal experience, yet you're happy to spread rumour. Stratstone, like any other large company will have its fair share of numpties. However, they ARE the largest retail used an new car group in Europe. That doesn't happen by accident. I have used them for years without any more issues than any other LR dealer I've been to. For the O/P, air suspension shouldn't drop when parked so it could be a pinhole leak in one of the airbags. As regards pulling to the left that can be a balljoint. Also identified by a light metallic knock on uneven roads and you can sometimes feel it if you pull on the track rod. Happened to my 07 TDV8 so I changed both track rod ends and had the full car geometry set by Stratstone Solihull. Now perfect. If you take it somewhere other than LR for the tracking, make sure they put it in tight tolerance mode before setting the geometry. |
29th May 2011 4:28pm |
Sorry, yes I have had a bad personal experience with Stratstones but didn't want to hijack the thread with unnecessary details. But as you've asked:
29th May 2011 4:59pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I have my 2007 booked into the dealers next week to get the auto locking on moving and also the lazy locking done as well as the height sensors calibrated they are going to try and fit it all into 1hr which if they manage it will cost me a rather bizarre £101 plus VAT. I can confirm that the follow me home lights on for 40 seconds is simply activated by flashing the headlights with the key out, or in, or in then out, whatever, you get the picture i'm sure Geoff |
29th May 2011 7:21pm |
Folks
29th May 2011 8:30pm |
John60 Member Since: 13 May 2011 Location: Bedfordshire Posts: 12 |
Re Stratstone, when I was looking to buy my new car, I walked into the showroom of a nearby Stratstone dealer which had some electrical work in progress in the showroom. The conversation went
29th May 2011 8:55pm |
Height sensors need re-cal because the car doesn't sit level. Advice on the forum suggested a trip to a main dealer or I could start bending brackets.
29th May 2011 9:33pm |
That's a good thing, if they lend you a new TDV8 it will just ends in tears as you reach for your wallet Geoff |
29th May 2011 9:40pm |
