![]() | Home > Maintenance & Mods (L322) > Bilstein rear air spring failure |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 ![]() ![]() ![]() |
Nothing yet. |
Bilstein have advised Island4x4 that the air-springs need to be returned to Bilstein. Island4x4 have again advised that previous failures have only occurred after wheels have been free hanging, which I assume refers to the vehicle being on a hoist rather than without shock absorbers fitted, but I'm requesting confirmation of meaning because there is a huge difference.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
sorry to hear you are getting the runaround. OE spring fitted? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
The new LR springs arrived at the local servo yesterday which I collected today and hope to fit tomorrow during a brief break in the weather.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
I know that this will not help your case but when I fitted an aerosus replacement bag and it failed on initial inflation all I had to do was send a picture of the bag and received a full refund.
I sent pictures when requested but I suppose that Bilstein might want to closely inspect the failure point, although the pictures clearly show that they both split from almost the top to almost the bottom.
J2B Member Since: 03 Jul 2020 Location: kent Posts: 52 ![]() ![]() ![]() |
Need an airbag for mine (2010 4.4tdv) mrs had a suspension fault pop up and it was sitting on it's arse to the passenger side when left in normal ride height overnight, I've used Island 4x4 numerous times, never had an issue.Looked on their website today and the mentioned bags RKB500240 Bilstein part number is 40-240732 were still available was looking to order a pair, any way got distracted logged in to Island later and the bags weren't listed,(maybe out of stock)but Bilstein may have found a fault, the Island site has crashed at the moment so not sure if it was a glitch or myself being blind maybe worth you checking so as to get a credit or a refund if you already haven't. |
I got a refund after Bilstein supplied replacements to the supplier. I hope that Bilstein have discovered a flaw in the design or the material so that they produce one that doesn't explode when extended.
That's good news getting a refund , I'm blind they still have the Bilsteins listed,glad it got sorted |
Matthew Arber Member Since: 06 May 2020 Location: VICTORIA Posts: 1 ![]() ![]() |
The same thing has happened to me 3000kms from home and only recently replaced as preventative maintenance 3 months ago before our trip away.
Not unexpected unfortunately for anyone who uses off-road height. |
paulN186 Member Since: 28 Jun 2022 Location: edinburgh Posts: 39 ![]() ![]() |
Did the replacement aerosus work out ok no leaks ? |
Yes no issues (a small amount of drop overnight gradually stopped happening) , although I should have replaced the whole struts as one shocker is banging a bit and I returned after a month in the UK to a puddle of oil underneath the culprit.
