Home > Maintenance & Mods (L322) > Bilstein rear air spring failure
Page 3 of 3 <123
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Any updates Graeme? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #638123 28th Jul 2022 11:21pm
GraemeS
Nothing yet.
Post #638127 29th Jul 2022 1:34am
GraemeS
Bilstein have advised Island4x4 that the air-springs need to be returned to Bilstein. Island4x4 have again advised that previous failures have only occurred after wheels have been free hanging, which I assume refers to the vehicle being on a hoist rather than without shock absorbers fitted, but I'm requesting confirmation of meaning because there is a huge difference.
I'll contact Bilstein Australia to see if I can send an air-spring to them.
Post #638568 3rd Aug 2022 8:07am
ffrr14
sorry to hear you are getting the runaround. OE spring fitted? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #638634 4th Aug 2022 4:51am
GraemeS
The new LR springs arrived at the local servo yesterday which I collected today and hope to fit tomorrow during a brief break in the weather.
Bilstein Australia is not a subsidiary of Bilstein so were unable to assist. Hence the springs will have to make the journey back to Island4x4 at more expense. However I really need to know the possible warranty outcomes before incurring the postage cost considering that I have now bought original LR versions so have no need for more springs and that I have no confidence that another pair of Bilsteins wouldn't have the same issue. Will Island4x4 or Bilstein pay for their return? Will I be provided with a refund for what I paid plus the majority of the original freight? (I purchased a couple of smaller items with the springs.)
Post #638658 4th Aug 2022 9:48am
dingg1
I know that this will not help your case but when I fitted an aerosus replacement bag and it failed on initial inflation all I had to do was send a picture of the bag and received a full refund.
In your case, and the way you seem to be getting Censored about, I'd cut my losses.
If you used a credit card go section 73 if its available to you in Australia
Post #638663 4th Aug 2022 10:19am
GraemeS
I sent pictures when requested but I suppose that Bilstein might want to closely inspect the failure point, although the pictures clearly show that they both split from almost the top to almost the bottom.
Some discussions will take place as I think this failure will happen to all of this particular product but if I walk away then nothing will be done to prevent further incidents. Not incurring further costs is certainly on my mind though.
Post #638676 4th Aug 2022 12:33pm
J2B
England 2010 Range Rover Vogue TDV8 Ipanema Sand
Need an airbag for mine (2010 4.4tdv) mrs had a suspension fault pop up and it was sitting on it's arse to the passenger side when left in normal ride height overnight, I've used Island 4x4 numerous times, never had an issue.Looked on their website today and the mentioned bags RKB500240 Bilstein part number is 40-240732 were still available was looking to order a pair, any way got distracted logged in to Island later and the bags weren't listed,(maybe out of stock)but Bilstein may have found a fault, the Island site has crashed at the moment so not sure if it was a glitch or myself being blind maybe worth you checking so as to get a credit or a refund if you already haven't.
Post #647726 8th Nov 2022 9:33pm
GraemeS
I got a refund after Bilstein supplied replacements to the supplier. I hope that Bilstein have discovered a flaw in the design or the material so that they produce one that doesn't explode when extended.
I had purchased replacement genuine LR air-springs from this supplier prior to being advised that a refund would be forthcoming.
Post #647739 9th Nov 2022 6:23am
J2B
That's good news getting a refund , I'm blind they still have the Bilsteins listed,glad it got sorted Thumbs Up
Post #647785 9th Nov 2022 6:42pm
Matthew Arber
Australia
The same thing has happened to me 3000kms from home and only recently replaced as preventative maintenance 3 months ago before our trip away.
Blew when in off road height on nothing more than a sandy track Sad
Manufactured Jan 2022
https://photos.app.goo.gl/nJWJ4spwG3sauAE18
https://photos.app.goo.gl/znDdh5MKZdG2yp9c8
Post #662690 24th Apr 2023 10:24am
GraemeS
Not unexpected unfortunately for anyone who uses off-road height.
Post #662698 24th Apr 2023 12:17pm
paulN186
Did the replacement aerosus work out ok no leaks ?
Post #662802 25th Apr 2023 5:03pm
dingg1
Yes no issues (a small amount of drop overnight gradually stopped happening) , although I should have replaced the whole struts as one shocker is banging a bit and I returned after a month in the UK to a puddle of oil underneath the culprit.
A pair of struts (aerosus again) arrive tomorrow Rolling Eyes
Post #662807 25th Apr 2023 6:02pm
Page 3 of 3 <123
