Home > Maintenance & Mods (L405) > Retrofit Deployable towbar - how to |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Have finally managed to try and find out the part numbers for each of the different years
31st Mar 2023 11:58am |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 72 |
Following on for part C + D
21st Apr 2023 12:50pm |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 158 |
Hmm still looking myself for C&D brackets,
22nd Apr 2023 10:40am |
I don't have the brackets in hand to measure but I have found some close up photos, shouldn't be too difficult to take that design and make some measurements on the car if you wanted to draw them on cad.
24th Apr 2023 7:42am |
Oh that’s great well done, we can make a cad up and probably get some made. |
24th Apr 2023 4:54pm |
There are CNC plasma cutting services that could be used. I have a co2 laser that could be used to prototype a flat template for bending using acrylic. Not sure it's worth it for 2 sets though? bit of time with the grinder can fabricate a set up of sufficient quality |
24th Apr 2023 6:25pm |
Yes we need orders to make it worth our time, we have everything to make them no problem and can powder coat them as well. |
24th Apr 2023 6:34pm |
Fitted my towbar today minus the support bracket on my 2017MY. I figured I can get the bulk of it done and fit the support when I track one down as it doesn't require removing the bumper again.
29th Apr 2023 7:12pm |
Another minor update, if anyone wants to purchase the correct tow eye for the towbar its the same as an L322 or L494 one so readily obtained off ebay (I got one for £14 delivered).
9th May 2023 3:02pm |
Smoggie35 Member Since: 21 Nov 2022 Location: North Yorkshire Posts: 9 |
Thanks for this info Ryanmt. Just to confirm then if I already have deployable side steps fitted when I install mine all I need is to locate the socket in the harness in the spare wheel well?
11th May 2023 10:55am |
That bit of advice is for the my17 specifically. If you have the smaller infotainment screen you want the older style module. Good news is these are easily obtained (not my listing..just a bargain)
11th May 2023 7:55pm |
Thanks for the heads up. I have an MY16 AB so I’ll need the module you linked then. I’ll check first just to see what’s in the well as the spec for the AB says it’s deployable ready??
11th May 2023 9:18pm |
Pre MY17 the module is standalone and only controls the deployable towbar (same goes for the side steps which has its own dedicated module).
12th May 2023 8:06am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Surely you would just use the towbar no? Or am I missing something? |
