![]() | Home > Maintenance & Mods (L405) > Fuel burning heater |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
it wont work above a certain outside temperature..
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 192 ![]() ![]() ![]() |
Yes I get that it needs to be below a certain temperature. But it’s been plenty cool enough up here for sure
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 142 ![]() ![]() ![]() |
I don't think mine works either. I tried using it when there was ice on the car and the light flashed but nothing else. There should be a pump running but its all quiet. I tried it a couple of times and gave it up as not happening.
I’m going to be checking my battery voltage and if need be give them a ctek boost and then try next morning
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Yes you can. It's fine to charge from the posts. Kev
Thanks kev |
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 ![]() ![]() ![]() |
Fuel level needs to be above a certain point too, maybe more than 1/4 tank. 2017 SDV8 Autobiography |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
My FBH (and everything else inc the tailgate) worked fine when the main battery was at 10v and being backed up by the second battery so don't rely on voltage being the only issue... |
