Home > Maintenance & Mods (L405) > Fuel burning heater
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Fuel burning heater
Good afternoon everyone
I have a new to me 2016 4.4 sdv8 and the fbh doesn’t seem to work.
I’ve tried using it onscreen to set it time control when I go out to it the light is on the dash but no heat
It also takes longer to warm up than my l322 indicating to me that it’s not functioning at all
Any ideas where I should start looking
Ps. I have no remote button to it either
Thanks 2016 4.4 diesel
Post #662598 23rd Apr 2023 11:33am
it wont work above a certain outside temperature..
have a look at the fbh info in the wiki.. ... - .- -.
Post #662599 23rd Apr 2023 11:41am
Tdtj
Yes I get that it needs to be below a certain temperature. But it’s been plenty cool enough up here for sure
I’ll check wiki out
Thanks Stan 2016 4.4 diesel
Post #662600 23rd Apr 2023 11:44am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I don't think mine works either. I tried using it when there was ice on the car and the light flashed but nothing else. There should be a pump running but its all quiet. I tried it a couple of times and gave it up as not happening.
I did a bit of reading around it and because the engine isn't going to be running then it needs a certain battery charge before it'll fire up. I replaced my main battery recently but not the auxiliary one. I assume the heater will operate off the main battery but it may not. So I figured it may be a battery voltage to low creating my own non-fire situation.
Post #662669 23rd Apr 2023 9:08pm
Tdtj
I’m going to be checking my battery voltage and if need be give them a ctek boost and then try next morning
Can you connect the ctek to the posts under the bonnet? 2016 4.4 diesel
Post #662738 24th Apr 2023 7:31pm
knwatkins
Yes you can. It's fine to charge from the posts. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #662746 24th Apr 2023 8:45pm
Tdtj
Thanks kev Thumbs Up 2016 4.4 diesel
Post #662747 24th Apr 2023 8:54pm
recordman
United Kingdom 2017 Range Rover Autobiography SDV8 Aruba
Fuel level needs to be above a certain point too, maybe more than 1/4 tank. 2017 SDV8 Autobiography
Post #662754 24th Apr 2023 9:38pm
My FBH (and everything else inc the tailgate) worked fine when the main battery was at 10v and being backed up by the second battery so don't rely on voltage being the only issue... Thumbs Up Pete
Post #662775 25th Apr 2023 9:17am
