![]() | Home > Wheels & Tyres > Tpms sensors |
Overfinch JR Member Since: 03 Aug 2019 Location: Oldham Posts: 6 ![]() ![]() |
Anybody know if lr070840 lr156918 tpms sensors are interchangeable/same ? |
That’s what I thought but my L405 won’t read the LR156918 which is what’s fitted to the L460 🤷♂️ |
Ryanmt Member Since: 14 May 2015 Location: Warrington Posts: 76 ![]() ![]() ![]() |
I think they need to be activated with the correct tool first, have you tried that? |
AnnualMan Member Since: 16 Apr 2023 Location: Zurich Posts: 175 ![]() ![]() |
Interested in the answer to whether activation is required. I’m being quoted £750 by a specialist (not main dealer) to supply and fit 4 TPMS! Seems crazy when they can be had for about £30 a pop:
Molloy9999 Member Since: 28 Feb 2025 Location: Essex Posts: 6 ![]() ![]() |
Hello, did anyone manage to get L405 to see LR156918 TPMS sensors. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
I swapped all 4 on my 16 when I changed the wheels, They didn’t need any programming. Have also swapped on on my D5 which was read automatically.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 167 ![]() ![]() ![]() |
The aluminium stem type should just read automatically however the rubber stem type need to be programmed if used on a L405. I think a tool that can reprogram is around £120 or a decent tyre shop should be able to do it for not much money as it is a quick job and does not need tyres remounting etc. |
Full story :- I brought some 2023 L461 (style 5127) alloys and tyres for my L405. Originally my car was aluminum type 433mhz sensors and the new wheels are 433mhz rubber sensors. I have read the rubber sensor codes per wheel and programmed them into my car using an Autel tool. But i still get "TPMS system fault" after driving for 15 min.
