Home > Technical (L322) > 2006 4.2SC Rich Running |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 889 |
Replace the maf with a genuin part the chinease supplied one from AF caused me all sorts of issues. I know you cleaned it but replace it. |
15th Apr 2023 5:37pm |
theepicsponge Member Since: 19 Dec 2022 Location: Liverpool Posts: 7 |
Cheers Dave. I'm not totally convinced the issue is MAF just yet. The genuine MAF I already have was pretty clean anyway, but I thought I'd give it a clean seeing as I was replacing the filter anyway.
15th Apr 2023 5:47pm |
I plug my id tool in tomorrow and check my maf readings for you as a comparison |
15th Apr 2023 8:34pm |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 74 |
I realise the 4.2 is a different beast to the 5.0 but have you checked your oil recently? See if it smells of fuel, that was the problem on mine. The PCV was sucking the fuel vapour back into the intake and hey presto rich running. |
16th Apr 2023 8:55am |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
i would defo replace the pcv with a gen new one oil ingress makes the rubber very soft and distorts it tears easily new vehicle purchase
16th Apr 2023 10:13am |
Rackers - Cheers for the pointer. I've recently changed my oil and it did not smell unusually fuelly. It did have a slight stink to it, but nothing different to what I usually smell on my other cars/bikes
16th Apr 2023 10:28am |
My running rich issues was the common O ring at the back of the engine yes it's on my sport but dame engine same issues. Also check the vac pipes at the rear. You can see my video here on 2nd page
17th Apr 2023 6:27pm |
Very useful thank you! Was that leak from the black hose you can clearly see, or was it underneath the supercharger? |
17th Apr 2023 7:22pm |
The pipe goes into a push fit connector in the top of the block the O ring fails, common issue. |
17th Apr 2023 8:48pm |
Just to follow up on this issue. It turns out my Precat / Upstream O2 sensors were both dead
25th Apr 2023 9:37am |
