![]() | Home > Off Topic > Brian James Trailers? |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 ![]() ![]() |
Had a well used second hand flatbed with sides a number of years ago.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
I have a small Brian James 4 wheel car trailer. No real issues, apart from the rear lamps (poor connections to the bulbs). Changed the jockey wheel & winch due to rust. But I have had it for 20 years now. |
Hanwellfields Member Since: 22 Dec 2022 Location: Oxfordshire/ Cotswold Posts: 89 ![]() ![]() ![]() |
Thanks for the feedback Chugga and Highroller. |
I only use mine for towing my classic race Mini. Even with the four wheels it's easy to manover.
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
From my limited experience with caravan movers.
It is not always possible to reverse a trailer into some positions no matter how good you are at it |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 371 ![]() ![]() ![]() |
Normally with a twin axle caravan they have two movers working in tandem. I would not recommend trying to move it with the jockey wheel extended and the trailer loaded as they can bend!
A huge thank-you for all the advice.
Agree on all counts. Terrific trailers but by their very design they are heavy. I did try the same thing. When empty you can move with the jockey wheel. When loaded = no chance... Our drive means the RR is on quite a lot of lock. Hence the look at the motor mover. To reduce the stress on the hitch etc. Current: L322 2011 Zermatt Silver TDV8 Vogue SE, MB GLB AMG35, Renault Clio R200 Cup Previous: Audi RS4 Avant Nogaro, Audit TT Sline, BMW M3 E92, BMW Z4 3.0i SMG, Macan GTS, Boxster S 986, Touareg V6 TDI |
