Home > My Range Rover > Project TDV8
Page 2 of 3 <123>
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Thanks for the info, at least I know it's available and do-able. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #657942 27th Feb 2023 5:16am
dhallworth
Finally got around to having a look at my friends TDV8 today.
Removing the plug from the rail pressure sensor, cleaning it with contact cleaner and refitting it seems to have done the trick on this one thankfully Smile
Post #659995 21st Mar 2023 8:46pm
Fatboy Slim
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Hi David! Brilliant!
This one has settled down now, ultimate fix was a new genuine Delphi rail pressure sensor, and I ran an overlay harness from the engine ECU to the sensor with a new harness connector for the sensor. On close inspection, the terminals in the original harness plug to the sensor have gone a bit baggy, though I'm not ruling out a duff wire in the harness as well.
Also managed to trace an intermittent battery drain issue to the passenger side heated seat coming on, even with the ignition off and the car locked Laughing seems to be a duff climate control panel.
Also have unblocked the sunroof drains which were absolutely solid, calibrated and adjusted the sunroof so it closes properly now..........
..........and found a load of welding to do Neutral
Joys of running posh tackle eh? Laughing
Post #660507 27th Mar 2023 6:03pm
Fatboy Slim
Ebay item number eBay Item No. 253685399767 for anyone that needs a harness plug that fits
Post #660508 27th Mar 2023 6:10pm
Fatboy Slim
Well that's the L/H turbo off..... what an absolute hound of a job
Post #661266 6th Apr 2023 10:21pm
Fatboy Slim
Aaaand that's the right hand off. In fairness, that one was worse to get off than the left!!
Post #661534 10th Apr 2023 6:28pm
Well done, a horrible job, especially in this cold weather.... Bow down Bow down Pete
Post #661535 10th Apr 2023 6:52pm
Fatboy Slim
Cheers Pete! Can honestly say they were the most horrible turbos I've ever removed in 25 years of spannering! If I had the facilities I'd have dropped the engine out from underneath.
Post #661538 10th Apr 2023 6:57pm
Thumbs Up Pete
Post #661549 10th Apr 2023 8:47pm
Fatboy Slim
Nasty side turbo in.....
All new pipes and hoses. Turbos refurbished by Midland Turbo
They turned them around pretty quickly.
Just need to get the R/H in now!
Post #662475 21st Apr 2023 8:31pm
evotime
Good Job. I love threads like this, most informative Thumbs Up X5 40d
Post #662493 22nd Apr 2023 6:03am
Fatboy Slim
Day off from turbos today. Left hand is pretty much wrapped just the right hand left to do. Time isn't my friend this weekend so thought I'd dip into some other jobs instead.
Noticed when I went to remove the turbos that there wasn't any refrigerant left in the system, rigged the recovery gear up to find an empty A/C system......so thought I'd do a bit of leak hunting.
System pressurised with nitrogen...
One leaking condenser found:
Post #662595 23rd Apr 2023 10:50am
Fatboy Slim
Double post Whistle
Post #663315 2nd May 2023 8:13pm
Fatboy Slim
Plodding on slowly when time allows. R/H turbo done:
Thought I'd change the badly stuffed rear prop carrier bearing before I put the exhaust back on:
Post #663316 2nd May 2023 8:15pm
Fatboy Slim
Well it lives!!! Very Happy actually used her in anger today for the first time! Goes like a bomb.
Was in such a good mood with her I even fixed the parking sensors Laughing
Post #663911 11th May 2023 9:46pm
Page 2 of 3 <123>
