![]() | Home > Maintenance & Mods (L405) > A rust trap on your L405 you probably aren't aware of.... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8414 ![]() ![]() ![]() |
It's a plastic tailgate so they had to put some ferrous metal in there somewhere, and of course, leave it untreated.... |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
It’s ok the sunroof drains will have totalled the car way before that causes a concern |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1618 ![]() ![]() ![]() |
Thank God I have a “poverty spec” car, without roof drains or Dynamic Response corrosion to worry about, although my crankshaft is forged from high-density carotene, of course (yawn) |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Thanks for the heads up gremlin... Ill have a look at ours tomorrow |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1157 ![]() ![]() ![]() |
Yes, thanks Gremlin will check mine also. overfinch modified |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
May be not a rust trap, but if you want even more paranoia, pull out your front inner wing liners and check out the amount of leafs and stuff in there. |
Just went to look at mine and found this....
Anyone got a picture? I couldn’t quite work out where I am suppose to be checking |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Same here. I've just been out to mine to check. I can't see any rectangular holes back into the body :-s
Gremlin , a picture would be good. Poor Kev has spent the whole of easter Monday looking for this rust trap |
Its been mentioned before, there's nothing really to stop (unless you park your car in a garage and only take it out in summer) leaves from near the bonnet hinge from dropping down inside the wing in the void between the wing and the body, the foam doesn't really do much. |
I have indeed ![]() ![]() 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Ah, sorry guys, I’ll try to take a picture, but big day tomorrow its the annual 4K service!
