Home > Technical (L405) > Idiosyncrasy - Larger Oil filter for TDV6 than SDV8? |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1129 |
Surprised to hear this Gremlin, I agree you would think it would be the other way around! overfinch modified |
8th Apr 2023 9:12am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Yes, that's right Gremlin and something I've thought about previously.
8th Apr 2023 1:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 730 |
Has it always been bigger? were the earlier TDV6 engines fitted with a smaller filter that was later quietly upgraded by JLR in an effort to reduce the number of crank failures?
8th Apr 2023 3:03pm |
No. It's always been the same on the 3.0 since the engine came out in 2009. There was a change in the filter and associated housing design when the 2.7 was partially re-designed to form the 3.0. Kev
8th Apr 2023 3:37pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3738 |
The larger filter is needed to absorb the bits of crankshaft, bearings and rings 😂➡️ 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
8th Apr 2023 5:19pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7922 |
8th Apr 2023 5:50pm |
Nonsense - It's all a myth, there is no problem with the crankshafts apparently |
8th Apr 2023 6:01pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1417 |
“If it ain’t broke, don’t fix it” -where’s the fun in that? |
8th Apr 2023 6:14pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
8th Apr 2023 10:17pm |
8th Apr 2023 10:45pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1177 |
From my basic understanding, the 6 engine was designed for smaller engine bays and even transverse fitting, it has a smaller number of main bearings for the crank shaft than the 8 engine.
9th Apr 2023 3:19am |
So it seems that my comment about being crank related wasn't far away.
9th Apr 2023 10:28am |
Some never pass up an opportunity … |
9th Apr 2023 5:58pm |
