![]() | Home > Technical (L405) > Idiosyncrasy - Larger Oil filter for TDV6 than SDV8? |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
Surprised to hear this Gremlin, I agree you would think it would be the other way around! overfinch modified |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Yes, that's right Gremlin and something I've thought about previously.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
Has it always been bigger? were the earlier TDV6 engines fitted with a smaller filter that was later quietly upgraded by JLR in an effort to reduce the number of crank failures?
No. It's always been the same on the 3.0 since the engine came out in 2009. There was a change in the filter and associated housing design when the 2.7 was partially re-designed to form the 3.0. Kev
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
The larger filter is needed to absorb the bits of crankshaft, bearings and rings 😂➡️ 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Nonsense - It's all a myth, there is no problem with the crankshafts apparently |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1587 ![]() ![]() ![]() |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
From my basic understanding, the 6 engine was designed for smaller engine bays and even transverse fitting, it has a smaller number of main bearings for the crank shaft than the 8 engine.
So it seems that my comment about being crank related wasn't far away.
Some never pass up an opportunity … |
