Home > Technical (L405) > Reverse mirror tilt problem
tuki
Turkey 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi again,
It may sound a little stupid but I couldn't solve the problem that I'm having with my new MY20 P525.
So after driving my beloved L322 for 5 years, I got myself a 2020 P525. Loving every bit of the car but the side mirrors seems like they don't like me that much Laughing
The problem is, and my car is a left-handed fattie, when I put the car on reverse the driver side mirror tilts down, where passenger side should have to do. I tried to select the mirror side to the right from the door switch, but nothing happens. Switched on/off the tilting mirror option from the dash menu but no go. I'm fed up tilting the passenger mirror every time when I'm backing not to hit the curb.
I checked the owners manual, states that dipping position can be saved to seat memory when the vehicle is in ''R'', tried it but just the left mirror can be adjusted, right one doesn't tilt up when you go back in P.
Any advice will be highly appreciated Bow down
Post #660767 31st Mar 2023 12:44pm
I think you put it in reverse, then set the mirrors where you want them when you select reverse, then go back to park or drive and they will return to where they were before but remember the reverse setting.... if that makes sense....!! Pete
Post #660768 31st Mar 2023 12:50pm
tuki
tried it but just the left side mirror tilts back, nothing with the right one. The car is acting like it's a right-hander.
Post #660770 31st Mar 2023 12:56pm
Both of mine can be adjusted that way... does that mirror adjust OK normally...? Pete
Post #660778 31st Mar 2023 1:12pm
tuki
yep everything is working fine besides of the auto tilting function
Post #660781 31st Mar 2023 1:19pm
Maybe it's deeper in the settings and needs something in the CCF looking at... just guessing... Thumbs Up Pete
Post #660782 31st Mar 2023 1:21pm
Range Rover LSE
You can turn the reverse dip feature on or off in the vehicle settings menu, the option sits in the convenience features section. Can be accessed through the Menu button on the steering wheel and scroll down. Range Rover Sport 2023 D350 Autobiography
Gone RR L405 Autobiography SDV8, RR L405 VSE SDV8, RR L405 3.0L VSE, RR L322 BM 4.4, RR Sport, RR L322 TDV8 Vogue, Disco 4, Disco 3 (2 off), Disco 2 and RR Classic & RR LSE
Post #660907 2nd Apr 2023 10:29am
