Home > Technical (L405) > Stop start not functioning 2016 4.4 SDV8
MarianaWestminster
Hi all,
The auto stop start on my 16 4.4 SDV8 doesn't seem to function.
I measured the voltage on the main battery at 12.00v so decided to charge via the points under the bonnet.
Stop start then functioned for a couple of days but has now quit working again.
Main battery always measures between 12.00 and 12.5v
Happy to buy a new one if necessary but I'm not sure if these readings indicate it is at fault.
I have no other issues relating to a dying battery like others have mentioned on here.
Thanks in advance!
Post #660722 30th Mar 2023 9:54pm
TJH1985
My MY16 was fairly similar and on the original batteries, stop start worked occasionally after a long run but no other symptoms. I changed both, probably a side affect of being a previous L322 owner and now my stop start always works!
Most places I think inc Halfords will do a battery health check etc might be worth something more than a voltage check? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #660726 30th Mar 2023 10:15pm
Kot
I wish mine didn't work Big Cry 2018 SE SDV8 4.4 Byron Blue
Post #660727 30th Mar 2023 10:26pm
easy solution,
if you have an aux battery then you disconnect the negative wire,
if you have a capacitor then you disconnect the signal wire. ... - .- -.
Post #660738 31st Mar 2023 9:30am
caymanblack
Me too, Laughing first thing I do is switch it off. overfinch modified
Post #660747 31st Mar 2023 10:26am
MarianaWestminster
Hi Stan,
I actually want the stop start to work, I don't want to permanently disable it.
Had the main battery tested yesterday and it came back replace battery on the midtronics tester.
Will purchase and fit a new main battery and update this thread.
Post #660835 1st Apr 2023 10:57am
understood..
check the rear off side cubby and see if you have an aux battery in there .....if you have then check the voltage on that one...
if you dont then its the capacitor setup you have.. ... - .- -.
Post #660838 1st Apr 2023 11:11am
MarianaWestminster
I do indeed have the auxiliary battery.
It's the bigger one of the 2 (096?)
And measures close to 13v but my man didn't want to use the tester on it as its not the starter battery.
Charging the main battery brings back stop start for a day or 2 but as I said the tester shows replace battery so will get a new one and test.
Post #660840 1st Apr 2023 11:26am
just to clarify,
the battery under the spare wheel is your main battery and the smaller one [if you have one?] is in the rear offside cubby.. .. ... - .- -.
Post #660841 1st Apr 2023 11:35am
MarianaWestminster wrote:
Hi Stan,
JLR battery prices are quite competitive at the moment sir... Thumbs Up
Post #660843 1st Apr 2023 11:42am
MarianaWestminster
Yes Stan, I've an 019 main battery under the spare wheel which shows as 'replace battery' on the midtronics tester.
The 096 auxiliary is in the right hand cubby and measures almost 13v if memory serves me correctly
Post #660846 1st Apr 2023 11:56am
MarianaWestminster
I will make enquires, thanks Craig Thumbs Up
Post #660847 1st Apr 2023 12:00pm
Post #660848 1st Apr 2023 12:14pm
MarianaWestminster
New main battery fitted this afternoon, BMS reset and away we go.
Stop start now functioning on a quick drive round the block.
Hopefully it lasts!
Thanks everyone
Post #660879 1st Apr 2023 7:32pm
Thumbs Up ... - .- -.
Post #660880 1st Apr 2023 8:02pm
