![]() | Home > In Car Electronics (L322) > ipod or iphone in hse non tv screen |
There are dozens to choose from:
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 ![]() ![]() ![]() |
Hi Steve thanks for reply some good links there I presume they are just plug and play but do the connect to back of multidisc or would I have to take top of dash out and plug in behind the actual cd player mid thingy, also how do u take the Multi out of glove box? Cheers Range rover hse
Hi Steve the dension gateway 100 should work with rangie if it's BMW spec one for e53 or e46 Range rover hse
Yeah, the Gateway 100 will work. The drawback with most of these is that the emulate the cd changer - so you're best off setting up 6 playlists. The intravee gives full control but you have to find an Alpine Ipod adapter used as these or unavailable new (or check ebay - both are often sold together).
I installed the Intravee, you shouldnt have any problems in your HSE as it just uses the multi-line display.
