Home > In Car Electronics (L322) > ipod or iphone in hse non tv screen |
There are dozens to choose from:
26th May 2011 2:53pm |
993porky Member Since: 25 May 2011 Location: Sunderland Posts: 58 |
Hi Steve thanks for reply some good links there I presume they are just plug and play but do the connect to back of multidisc or would I have to take top of dash out and plug in behind the actual cd player mid thingy, also how do u take the Multi out of glove box? Cheers Range rover hse
27th May 2011 9:14am |
Hi Steve the dension gateway 100 should work with rangie if it's BMW spec one for e53 or e46 Range rover hse
28th May 2011 2:58pm |
Yeah, the Gateway 100 will work. The drawback with most of these is that the emulate the cd changer - so you're best off setting up 6 playlists. The intravee gives full control but you have to find an Alpine Ipod adapter used as these or unavailable new (or check ebay - both are often sold together).
29th May 2011 11:39am |
I installed the Intravee, you shouldnt have any problems in your HSE as it just uses the multi-line display.
29th May 2011 11:48am |
