Home > Technical (L322) > Is any oil OK if it meets the spec?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Having a conversation today, and I thought that provided an oil meets the LR specs, it would be OK?
for example, Mannol have an oil, spec says STJLR.03.5003 and ACEA A5/B5 and is fully synthetic, but it is pretty cheap compared to others available here in France.
Best avoided or OK?
Post #659333 14th Mar 2023 5:49pm
Phoenix
It's the correct specification - as in it meets the minimum requirements, they are a decent brand but don't have the manufacturer affiliations of Mobil, Castrol etc.
Personally i wouldn't hesitate to use it provided the vehicle isn't continually being worked hard and service intervals extended.
Post #659341 14th Mar 2023 6:24pm
philip1972
Cheers.
Car does not work hard and I change the oil more often than schedule says Thumbs Up
Post #659347 14th Mar 2023 7:09pm
Phoenix
Then buy it, relax and spend the savings on some good wine & cheese.
Well that's what i'd do!.
Post #659363 14th Mar 2023 8:20pm
knwatkins
I've used Mannol oils previously and not had any problems. If it meets the spec, it meets the spec. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #659377 14th Mar 2023 8:45pm
RiverBlanche
Hi,
agree with above ^ got an oil change on the D3 next week and 5L of mannol arrived last week ready for the change it was £16.50 delivered, correct spec and only needed the 5L as still got some from last time
The D3 spec is w2c913-D
Post #659676 17th Mar 2023 8:21pm
Kot
 2018 SE SDV8 4.4 Byron Blue
Post #659681 17th Mar 2023 9:06pm
Gremlin500
Thumbs Up ditto from me too,
If it meets the spec, and there is no higher spec, you can’t really improve on that, can you? Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #659691 17th Mar 2023 10:12pm
