![]() | Home > Technical (L322) > List of faults even after new battery fitted. |
RAGE72 Member Since: 21 Jul 2021 Location: Goole Posts: 32 ![]() ![]() ![]() |
Ok i will have a look at this when i get home tmrw if its not raining.
It won't be the ABS pump pulling the power down to 4V, it will be a bad connection upstream. What you need to do is go connector by connector, fuse by fuse back towards the battery, checking the voltage either side whilst the fault is apparent, at some point you'll get a low reading on one side but a battery voltage the other, firstly though, use your nose & eyes to look / sniff for any signs of overheating, high resistance almost always causes the area around it to heat up (dependent upon current draw) which will result in discolouration or even deformation. |
It will have to be something common to the small group of fuses in question. All the cables from this mini fuse board all exit via loom towards the abs unit. When the pump is connected all of these fuses are pulled down simultaneously going to have to dig around fir some diagrams ti see where these are all supplied from. |
So the fault is that the small fuseboard 'B' that i was getting low voltage on def has an issue getting its power i temporarily have taken power from the large stud 'C' to the left hand of this main fuseboard and entered it via a 40a Fuse onto the small seperate fuseboard 'A' thats to its right all within the fuseboard located over the front offside wheel under bonnet and its fine all faults clear starts right up and no volt drop. So i need to determine where this board 'B' gets its feed/s from to find the actual fault. Can anyone also advise whats the difference between these 2 power sections as in vehicle timeouts etc as that will determine how urgent the proper fix is as currently the 2 sections are now powered at the same time.
You should be able to work it out from this.
Hi I cannot locate the details of this small auxiliary board Internet draws a total blank. The area where this small fuseboard is on everything I find is just a space.
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
I understand your pain. I have a couple of Freelander 2's in the family. My daughter had a new alternator fitted in the grey car as the voltage was 16 volts. THe mechanic then said it needed a starter motor. The engine was then found to be seized. Right, I told him he was a W***r and he got upset. So, I put the diagnistics on it. No Lin bus, no communication, fusebox voltages all over the place. So dead short somewhere, perhaps. Found repaired wires in the engine loom, pulled the engine out and put a second hand low mileage engine in. NO start, checked all the faults again, ah, temperature sensor and oil level switches not compatible. By now Iwas a bit P***d off. Took the starter motor off, and took the solenoid out, surprise, the solenoid was jammed and the starter key in check had therefore not finished the check-sum to set the ECU. I put another starter in and reset all the fault codes, away it went! THe old engine was now turning over. I changed all the relays and fuses from a second hand fuse box and it has been OK for the last year. Long story, but often its not what you think is wrong but because of a simple mechanical fault, ie, made in China starter motor. Not a Rangrover, but still a Landrover of the same era. |
Your vehicle profile is misleading - the schematic I posted is for up to 10MY, from the VIN in one of your photos, yours is a 10MY. The schematic will be different, if you can't get hold of the correct 'battery mounting and cables' for your MY - which has the distances from connections to splices annotated, then you're going to have to open up the harness to find the splice. |
Profile I agree I appear to own a 2010 rangerover but it is 2009 59 registration and appears to have a lot of extra cables from normal. I can't even find any details of any vehicle having this additional 12 way auxiliary board.
Well if you are hesitant about opening up the harness, you could use a FLIR or IR thermometer to find the 'warm spot', or use a TDR to find the distance to the disturbance, both methods are common in fault finding in automotive, fixed installation and HV distribution networks.
TDR would be usefull but as its not something I do regular it's not really something I wanna splash 600plus on. I'm not sure topic would really give me the information need. Once it cokes back from garage where its having brakes bled after removal of pump I will have to have a look at the fuseboard behind glove box and see of there's anything obvious. I reluctant to allow the fault to show again as don't want to keep subjecting the electrics to 4.5v. All I need to know is where this board is fed from might try a cable tracer ot just look for something obvious or the strange hidden fuses on backnof the main glove box board that having dug into this some people have had issues with. Its clearly not a blown fuse just a bad board, connector or splice someplace. At least she's running again in the interim. Thanks for help so far I do appreciate it |
Just to close this out i eventually found a burned connection behind the fuseboard behind glovebox i re made the connections and bingo never skipped a beat since i will add i spent a total or around 80 hours going through all kinds of issues until i finally found this.
