![]() | Home > Technical (L322) > Want to tow RV... what am I missing here? |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
6000 lbs is about 3 ton in English money, that’s a far bit for one of these? Not entirely sure about US regulations regarding the towing set up, just hope one of your brethren pops up with the answer.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Late L322s already have the towing ECU, so any dedicated electrics kit will be plug and play.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, you say 6000lb RV, if that's going on a trailer the combined weight should not exceed 3500kg, or about 7,700lb, so the trailer you pulling it on should not exceed 1,700lb.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
Being a bit of a "belt & braces" guy I use a breaklaway cable attached to the towbar & chains - does this mean I should not use chains as well ? |
I must admit I didn't know you weren't supposed to use chains in the UK, I always have.
The point of the breakaway cable is to apply the handbrake to the trailer before snapping itself loose from the vehicle, so the trailer brings itself to a stop but not the vehicle, which is deemed dangerous.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
The American braking system for trailers is electrically operated so not sure this forum is the best to ask as we (mostly I assume) have mechanically operated braking systems. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
I am in Australia, possibly similar setup as the US?. I have wired up 2 vehicles that have had the UK harness and plug fitted in the factory or dealers here and both were wired up completely wrong for local wiring spec. My cars both had the trailer module and harness fitted, later cars have a gray plug by the spare wheel afaik. Biggest thing is the electric brakes, law over here, you need to run a feed from the light control module to your brake controller then another to the trailer plug in the rear. Also a big issue if your trailer has LED lights, you will get constant flashing as the car sends out test pulses. I made a shunt box with relays and load resistors that I can swap between cars.
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 512 ![]() ![]() ![]() |
a pedantic point but Gary mentions attaching to breakaway cable to the tow bar, maybe a slip of the finger but the breakaway cable should be attached to a part of the car that isnt part off the towing assembly, so if the towing assembly fails away. and the trailer separates from the car, the breakaway cable doesn't remain attached to the bits that have also broken away (it wont then work). First time FFRR owner |
Very true - although I know on my L322, the crossbeam is right against the underside of the body, so there is nowhere else to attach it, but on my L405, an extended breakaway will go around the crossbeam or bracket on the underside. 2015 Range Rover Autobiography 4.4 SDV8 |
