Home > Technical (L322) > Steering judder under moderate braking at high speed
JayGee
Under hard braking or light braking or at low speed it's fine. The steering wheel rocks quite alarmingly side to side. Couple of months ago had new (Genuine) disks and Delphi pads fitted and it's also had the front upper and lower arms replaced ( Genuine ). Tried sequential heavy braking at speed to see if it was uneven disk friction but no change. I doubt it's a warped disk but it could be the disk to hub wasn't 100% cleaned but I'd have thought excessive disk runout would show up under all braking situations. Anyone got any ideas? 2012 TDV8 Vogue (L322)
Post #653547 14th Jan 2023 12:30pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Had a similar thing last year, it turned out to be ever so slightly worn drop links causing the judder. Changed and now perfect. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #653568 14th Jan 2023 4:16pm
JayGee
Thanks - that's an easy enough fix! 2012 TDV8 Vogue (L322)
Post #653569 14th Jan 2023 4:26pm
JayGee
Replaced both outer steering tie rods and the judder is much reduced but still noticeable. Car feels much nicer to drive though as the steering is more precise and it doesn't 'float' in a straight line at speed. I'd kind of got used to this as the nature of the car but glad it's now gone. 2012 TDV8 Vogue (L322)
Post #659032 10th Mar 2023 11:30am
kevinp
My brakes gave me similar symptoms with a light shudder felt through the steering wheel and it was a rear brake caliper at fault. With new ones fitted everything was back to smooth braking. Don't know why it made the steering wheel shudder though! I can do high speed braking with confidence now.
Post #659036 10th Mar 2023 12:14pm
JayGee
I replaced the rear callipers last year and it started when the front disks and pads were replaced. I think I'm going to have to remove them and see if they are mated cleanly against the hubs 2012 TDV8 Vogue (L322)
Post #659040 10th Mar 2023 12:41pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi, when I was racing XJ-S's the discs used to warp so bad that the caliper pistons would knock back enough to require pumping the brake pedal at 145 mph to get the pads back against the disc. I tend to agree that the discs might not be hard against the hub face. Its worth putting a dial indicator to check the runout, and wobble the hubs about to check for bearing movement as well.
Post #659058 10th Mar 2023 7:52pm
