Home > Technical (L405) > Multiple seat faults, single cause?
66j
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Passenger seat has suddenly lost lumbar, bolster and massage functions. Can hear motor/pump on activating any of the three, but no resulting movement in the seat. Strikes me that a single failure affecting multiple functions. Anyone had similar experience? Thoughts on the fix? TIA
Post #657226 20th Feb 2023 3:03pm
Dan_Veluwe
Netherlands
Since all are pneumatic, sounds like a leak, or a hose clip failing.. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
PHEV P400e Hybrid Autobiography Loire blue= SOLD
D5 SD4 HSE Lux Corris grey = SOLD
D3 TdV6 HSE Lux Vienna Green =SOLD
P300 F-Type 2018 Ultra Blue = SOLD
25t F-Pace 2020 Loire Blue = SOLD
Post #657315 21st Feb 2023 10:41am
66j
Thx for response, makes sense. Any experience of accessing the relevant area?
Post #657317 21st Feb 2023 11:04am
Dan_Veluwe
Netherlands
I don't work on my own cars. All under warranty.
But this video is from the earlier model. Seems most can be reached by removing lower rear panel of seat..
Better check before you start though..
Post #657318 21st Feb 2023 11:12am
66j
I gained access to the back of the seat and the problem was immediately apparent.
#l405seatdisassembly
#l405seatfunctionfail
#l405lumbarbolstermassagefail
Post #658875 8th Mar 2023 5:25pm
Dan_Veluwe
Netherlands
I can not see the images.. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Post #658877 8th Mar 2023 5:46pm
66j
Gd evening. Can you see it now?
Post #658888 8th Mar 2023 7:19pm
66j
This was where I found the access guidance
Post #658889 8th Mar 2023 7:21pm
Dan_Veluwe
Netherlands
66j wrote:
Can you see it now?
Yes ! So it was exactly as I expected : disconnected. The hose clamp came off ? I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Post #658891 8th Mar 2023 7:43pm
66j
Sheared nipple on the outlet of the non return valve. Repair attempted, “part only available as part of replacement module” £££
Post #658895 8th Mar 2023 8:11pm
Dan_Veluwe
Netherlands
Take the NRV out of the car if not too complex.
Try to make an adaptor piece to refit te hose on the valve..
If you have access to a milling machine, you can make it from aluminum..
Or go and have a look at your garden centre, irrigation systems..
Post #658897 8th Mar 2023 8:29pm
66j
Will explore further options if in-situ repair is unsuccessful.
Thx for interest and input .
Post #658898 8th Mar 2023 8:42pm
