![]() | Home > Technical (L405) > Multiple seat faults, single cause? |
Dan_Veluwe Member Since: 04 Dec 2021 Location: Highlands ( Veluwe) Posts: 172 ![]() ![]() |
Since all are pneumatic, sounds like a leak, or a hose clip failing.. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
66j Member Since: 02 Aug 2018 Location: CM3 Posts: 18 ![]() ![]() ![]() |
I don't work on my own cars. All under warranty.
I gained access to the back of the seat and the problem was immediately apparent.
I can not see the images.. I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black
Yes ! So it was exactly as I expected : disconnected. The hose clamp came off ? I-pace First Edition Santorini & 2nd car Mazda MX-30 Advantage red/black PHEV P400e Hybrid Autobiography Loire blue= SOLD D5 SD4 HSE Lux Corris grey = SOLD D3 TdV6 HSE Lux Vienna Green =SOLD P300 F-Type 2018 Ultra Blue = SOLD 25t F-Pace 2020 Loire Blue = SOLD |
Sheared nipple on the outlet of the non return valve. Repair attempted, “part only available as part of replacement module” £££ |
Take the NRV out of the car if not too complex.
Will explore further options if in-situ repair is unsuccessful.
Kellen Member Since: 16 Dec 2024 Location: Seattle Posts: 11 ![]() ![]() |
Any update, think my seat is doing the exact thing. Taking the cover off tonight. |
Hi Kellen, I simply glued the offending item in place, taking care not to get any glue inside the tube or valve. Still works! Good luck. |
2021 rear seats just need 2 screws removed from the base of the seat, then the covers pops right off. Mine actually fell off.
