![]() | Home > Technical (L322) > M62 engine knocking (or what???) |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
On hard acceleration I get what sounds like engine knocking between 1900-2500 rpm. Mostly noticeable uphill but also while accelerating to overtake on a level road. Some days it's there (can pick up with a keen ear) even from lowish rpm with little load while some other (few) days it's totally absent, no matter how hard I am on the throttle.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
Vanos? |
I doubt it. They had no issues when I did the chains and hg last year. Also no timing error codes thrown. In fact I get no error codes on my car other than trivial stuff.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8510 ![]() ![]() ![]() |
Need an account to watch the video...!! Pete
Sorry, Pete. My bad.
I've probably ruled out any engine pinging / knocking etc. In a careful observation, the noise seems to occur between the 1900 and 2500 rpm range (most noticeable at 2300-2500). But it is not just while the rpm increase but also on their way down during an upshift (as the rpm needle drops back through said range). It has to be something loose that resonates at the particular frequency. Can't find it though |
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
The front driveshaft had problems on early cars, could be a UJ moving. |
It has had the recall done... |
I'm at my wits' end with this noise...Have inspected everything under the bonnet.
Had spoken earlier with a former LR dealership, now authorized garage about the issue and today dropped by to pick up their master mechanic, take the car for a spin and get his opinion.
Dandi Member Since: 08 May 2022 Location: Rome Posts: 9 ![]() ![]() ![]() |
Check driveshaft support bearing on my TD6 was failing and did knocking noise under heavy acceleration |
Grazie! Will do |
Wrapping this up once and for all:
Glad that's finally sorted.... |
Hey Pete,
