Home > General (L405) > Immobiliser choices
Killiestu
United Kingdom 2013 Range Rover Autobiography TDV6 Corris Grey
Immobiliser choices
Hi folks, looking for some advice on aftermarket immobiliser/ trackers.
Has anyone fitted a ghost / meta / scorpion s5 with tracker?
Post #658267 2nd Mar 2023 5:04pm
Overfinchbespoke
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
&t=7s
I have one fitted on my E Class Merc and will get one on a 405 when I can find the perfect car.
It completely stops the vehicle being moved from where you left it even if the thieves have the keys.
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Range Rover 2002 P38 4.6 Vogue
Range Rover 4.4 Vogue. Black
Range Rover 4.4 Vogue. Giverney Green
Mercedes S600L
Mercedes SL500 AMG
Mercedes E220 Estate Night Edition
Mulsanne
Post #658305 3rd Mar 2023 12:44am
Kot
Thumbs Up Ghost2
I dont use any proximity key, dont use the Ghost phone app, just a preset code using existing buttons etc
Also use Guardian mode with JLR Incontrol app 2018 SE SDV8 4.4 Byron Blue
Post #658308 3rd Mar 2023 6:54am
Killiestu
Great thanks folks.
I have downloaded the app but not really done much with it, so is that worth using then?
Post #658311 3rd Mar 2023 7:07am
Phil.
I’ve had the MetaTrack on my last 2 RR’s and it’s been good. I’d also recommend considering the Starline i96 as an alternative to the Ghost. Some of the features are better. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #658312 3rd Mar 2023 8:00am
Kot
Killiestu wrote:
Great thanks folks.
I wouldn't use the Ghost2 app as it uses BT and if you park close to where your phone is, (ie front drive next to house) then the Ghost2 can disable itself, leaving you with no protection.
Same as keyless--disable it! 2018 SE SDV8 4.4 Byron Blue
Post #658315 3rd Mar 2023 9:24am
Phil.
That's one of the advantages of the Starline i96 over the Ghost because you can turn down the app range so it only works if you are in the car. MY23 D350 HSE
Post #658316 3rd Mar 2023 9:26am
Rex the RR
Just had a smart trak imob 5 fitted to one of my cars, good so far! It uses a credit card sized fob, without the fob, the car won't start plus the added bonus of a tracker. It was about £500 plus £18 a month. Mainly for insurance purposes. I did notice smart trak have some specific land rover products.
Post #658318 3rd Mar 2023 9:44am
caymanblack
I have the same Rex. overfinch modified
Post #658325 3rd Mar 2023 10:29am
Phil.
Out of interest what is the distance the smart trak fob can be recognised by the car? I ask because some third-party fobs operate several meters away which makes them similar to how the the keyless system operates and therefore also require a faraday pouch. Others fobs require the user to press a button to avoid this potential risk. MY23 D350 HSE
Post #658330 3rd Mar 2023 11:22am
Rex the RR
Can't say 100%, but l have tried starting the car with the fob outside and it won't start. So I would say you have to have the fob in the car for it to start. Would need to have a look at the suppliers website regarding claimed range!
Post #658331 3rd Mar 2023 11:30am
