![]() | Home > Technical (L405) > Has you crankshaft failed? L405 3. 0 TDv6 only! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
One theory Ryan, is that as cars get over 3yrs old and fall out of the dealer network, the engine oil servicing falls way below the standard of oil JLR recommend... The engine oil used in the 3.0 does not mix correctly with "other" oils allowing clots (for want of a better term) to build up and eventually block oil journals... Usually the crank fails on the rear most crankshaft baring! This to me suggests the rear journals are the smallest oil ways and more susceptible to blockage...
The type of constructive and objective reply I'd hoped you might offer Craig. Very insightful and definitely one for owners to be asking those who service their cars about before any work is done (what oil do you intend to use?).
To keep things balanced; despite 17 votes to date all reporting no crankshaft issues:-
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I have a friend with a 2013 L405 3.0 with over 280k kilometres on it and I dont think its ever been serviced on time in the last 5 years and never by a main dealer since he got it in 2015. He would put cooking oil in it without a second thought and I also have a customer with a 2016 discovery with a 3.0 in it and it ate its crankshaft with 12k kilometres on it. He did get a new engine gratis as it was less than a year old at the time. Just my personal experience,, I do like the 3.0 engine and it suits the L405 but my preference is for the 4.4
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I have now owned 1 Disco and 3 RRS fitted with the Sdv6 and Tdv6 engines and never experienced a problem. That said the longest I kept any of the cars was 3 years.
Signing off as an L405 TDv6 owner after 6 happy and enjoyable years. That car proved itself very capable in all manner of circumstances, including effortlessly towing a trailer with another car on it.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Deleted for pedantry. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1570 ![]() ![]() ![]() |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
Not off topic if its the same engine |
The OP clearly states L405 3.0 only. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
And this is the L405 section of the Forum. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Christ.
Pedantry rules |
To be fair, this was posted in 2019… the title made clear it’s about L405 TDv6 experiences and the opening post made that clear too. Call pedantry if you like… some might call your posts on this particular thread … trolling 😉
