Home > Maintenance & Mods (L322) > Rear brakes
Rear brakes
Today i finished off changing my rear disc's and pads and a lick of paint. I asked on here a few months back if there should be a ring of corrosion round the rear disc's, and got told yer there should. Well after today i think this is very wrong. I've taken a few photos of my disc's and pads and the pad should break over the whole surface area not just a tiny bit. I'm amazed at how the breaks even worked considering the lack of breaking surface.
[/url]
photo (2)[/img]
[/url]
photo-1[/img]
[/url]
photo[/img]
And how the new ones look. (you can just see where they have started to bead in over the whole surface
[/url][/img]
Post #65787 25th May 2011 8:33pm
pretlove
i like tne new discs how much did you get them for and was it off of the bay of e? "RANGEISM WILL NOT BE TOLERATED"
Post #65816 25th May 2011 10:19pm
Tony
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Are they Britpart Discs or EBC, I was thinking of fitting Green pads?
Post #65823 26th May 2011 6:12am
reminds me, i have to do mine shortly.... Wink
Post #65824 26th May 2011 6:46am
Yer their the BritPart ones. Tried to get them of the bay but the guy was a ****** and never got back to me. Ended up getting them from Island 4x4. For fron and rear disc's, ebc ultimante pads, wear sensors front and rear and a rear wiper came to £176 all in. Got to work this morning with some very hot breaks, so need to adjust the handbreak shoes as they must be dragging Big Cry
Post #65825 26th May 2011 6:55am
Did the pistons move back freely when you put the new pads in? Hot brakes could be a sticking caliper. Previously..
Post #65828 26th May 2011 7:52am
Yer the pistons were fine. Its both rears that were hot. obviously havent backed the handbreak adjuster off enough. job for when i get home.
Post #65834 26th May 2011 8:42am
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Do you think the Britpart discs & the EBC pads are improving the braking now starting to bed in? 2008/58 FFRR 3.6 TDV8 Vogue
Post #67417 7th Jun 2011 12:29pm
I would say they are a bit better but not face distorting! They are squeezing a bit but getting better. They flutter a bit but that's due to the grooves.
Post #67433 7th Jun 2011 1:25pm
