![]() | Home > Technical (L405) > Suspension will raise when system cooled |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 753 ![]() ![]() |
"However as the l405 is so new to me and under warranty I'm going to have my first main dealer experience"
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 696 ![]() ![]() |
Thanks for the feedback Cass.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1273 ![]() ![]() |
With JLR extended warranty, You only pay for the initial diagnosis if it's not a warranty item, well that's my experience so far. I cant speak for other 3rd party warranties and their interactions with JLR dealers though. I had a suspension issue, and got LR assist out. https://www.fullfatrr.com/forum/topic59778.html Also MarianaWestminster, with you also having the JLR extended warranty, you could have called LR assist out and told them you were worried there is a suspension issue and worried it's not safe to drive. Ensure you tell the operator, that you need a LR tech otherwise you get the AA. Sometimes you are lucky and get someone the same day, sometimes you might have to wait a day or two. If the LR tech can fix the compressor/leak on site, they will. If not, they now can book you in at your local dealers immediately, and automatically, they can also book you a hire car as well there and then at your address. Thats a great advantage, as the dealer is on the clock ![]() Whereas booking direct with the dealer, they usually offers you an appointment, weeks into the future and 9 times out of 10 wont have a courtesy car available either. So moral in the storey, is to play the safety card where at all possible and use LR assist where possible. 2018 SE SDV8 4.4 Byron Blue |
Thats how I imagined it would work Kot, thank you for confirming.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
if you have LV assist ,you then call them and they could possibly fix your issue on your driveway.. ... - .- -.
I left Stockport 40 years ago ![]() ![]() |
I still work in Stockport but we moved out of the area last year... can't say I miss it either.
Driving back from visiting my mother tonight and I got an Amber 'normal height only message. All fun and games these Range Rovers |
Inspired by Kots success with it I purchased an Autel AP200. (Thought it might be a bit more convienient than my usual clunky SDD install on the laptop)
A good point with the AP200, is that its not locked to 1 vin, and you can use it on any model of the Landrover range.
Yes I liked that about it Kot as we also have a 2012 Sport Autobiography and a 2011 Freelander 2 so it can be used on both of those too and the other non LR vehicles in the stable for the small fee you speak of.
L405 went into Sytner LR Stockport yesterday and the compressor was found to be at fault.
Car collected and everything seems to be working as it should with regards to the air suspension.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8384 ![]() ![]() ![]() |
Glad it's sorted... |
