Home > Technical (L322) > Restricted performance
MitchMcd
Hi my l322 is showing restricted performance only does it when joining motorway etc goes away when I turn ignition off fault code I’m getting is P040D exhaust gas recirculating temperature sensor is this the map sensor on top of the inlet manifold cars a 2012 tdv8 westminster
Post #657905 26th Feb 2023 7:47pm
Dolphinboy
Get a HIGH pressure smoke test done. That will show you your leak - could be split inlet manifold (they are known for it)
Post #657924 26th Feb 2023 10:10pm
DrRob
As above, smoke test to see if you have a split hose/plenum or manifold.
You'll find a load of info on here using the "Search" button on the cause of RP
I'd be checking the 4 inlet hoses are the upgraded silicone ones as a quick and easy first step.
P040D is the exhaust manifold temp sensor on passenger side and doubt it's related to the RP from forum history. See "Wiki" page for how to replace that sensor. It's a bitch of a job. I got a specialist to do it. Use MMP in Dundee (Mike Park).
Welcome to the mad house Thumbs Up Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #657948 27th Feb 2023 7:47am
MitchMcd
Thanks for the replies will check the hoses etc at the weekend looks like it’s all the original hoses still on it only started doing it a couple of weeks ago as drove it on the motorway when I bought it and didn’t do it cheers Mitch
Post #658011 27th Feb 2023 7:26pm
Maximtaylor
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
My 2012 Westminster was doing the same thing a few weeks ago. I got the sensor replaced, which was the egt sensor in the manifold, but the restricted performance message came back. The PO40D code didn’t come back though Laughing
I made the mistake of not previously code grabbing with the fault ‘live’. I hope you’ve done this, because the PO40D is a common one and rarely the cause of running problems.
In my case the live code grab came back with P2264-OO (2F) water in fuel sensor circuit so I’m replacing filter and sensor as soon as it warms up.
Good luck!
Post #658014 27th Feb 2023 7:43pm
General
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
I've stolen Ninos picture to help explain.
The pipes shown by the red arrow are vacuum pipes,they are prone to perishing/collapsing.Check that they are all in place because when they perish they can either collapse under vacuum or slip off their fitting.It sounds like your problem is the turbo change over actuator,switches at 2500rpm and if it can't the car goes into restricted performance.
I have a 2012 Westminster and mine has just done the same as yours and my problem was the vacuum pipes coming off.Might be something else completely but it costs you nothing to check them. Thumbs Up
Post #658119 28th Feb 2023 7:14pm
MitchMcd
Hi thanks for the help I had a quick look at the 4 rubber hoses that go to the plenum only managed to get one off as it was getting dark I’m planning to remove and check all above mentioned on Saturday I’ll check those hoses too general as maybe Iv knocked something as I serviced it the other week just after I got it thanks agin Mitch
Post #658148 1st Mar 2023 8:47am
MitchMcd
Hi tried driving it with scanner plugged in got restricted performance at over 2000 rpm and only fault code I’m getting is P006A map mass or volume airflow correlation any one know what this is?
Post #658390 3rd Mar 2023 9:33pm
Baltic Blue
MAP is manifold absolute pressure..
Try cleaning the MAPT (Manifold absolute pressure and temperature) sensor.
5 minute job and costs nothing, so nothing to loose.
It’s the one sitting in the plenum.
Full details and description in the workshop manual.
Post #658410 4th Mar 2023 7:38am
DrRob
https://www.fullfatrr.com/forum/topic47735.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658412 4th Mar 2023 9:06am
Baltic Blue
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #658417 4th Mar 2023 9:46am
JayGee
Also check the MAF sensors on the air filter box outlets. The error may refer to a mismatch between the actual air mass measured by them and the calculated airmass from pressure (MAP), temp and RPM. 2012 TDV8 Vogue (L322)
Post #658419 4th Mar 2023 10:13am
MitchMcd
Hi managed to remove the donut plenum and check for leaks etc but didn’t find any or the 4 hoses was shocked with the amount of carbon build up inside the plenum got it cleaned up as good as new and took it for a blast went over 2500rpm with no restricted performance warning so hopefully it was the amount of gunk inside that was doing it I cleaned all sensors I could also so thanks for the advice and help 👍
Post #658536 5th Mar 2023 3:23pm
DrRob
Nice. As a matter of interest have you checked that your cross over valve for turbos at base of radiator has been upgraded from the early “nut” design? You can just about see it if you peer down the radiator area off centre right. Plenty of info on here. Search CSOV Thumbs Up
Done it for you Bow down
https://www.fullfatrr.com/gallery/albums/u..._TOPIx.pdf Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #658558 5th Mar 2023 5:45pm
MitchMcd
Hi mate I haven’t checked that is that done under recall?
Post #658562 5th Mar 2023 6:16pm
