Home > Technical (L322) > Should the viscous fan spin freely when disconnected?
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
TDV8 4.4l - as per other posts things are being taken out to fix a squeaky aux belt.
The question this time is simply, should the viscous fan freely spin when removed from the car? It, along with the cowling, are out of the car. The fan is smooth when turned, however it is stiff to rotate.
If disconnected, should it freely spin? Or is stiff normal? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #657737 25th Feb 2023 2:52pm
Ffrr-lover
I’ve had a look over YouTube but cannot find something that shows the fan spinning… or not. The closest i have gotten to is for a LR3 far replacement. Both the old and new seem to freely spin, and the design looks very similar to what i have.
I am leaning towards stiff is not good.
The new fan is at 9:50 into the video… (plus however long these bloody adverts are on for now)
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657761 25th Feb 2023 5:29pm
Ffrr-lover
This morning whilst working on the car again, i took another look at the removed viscous fan.
Sure enough, it is stiff like yesterday. In a moment of pondering I kept spinning it… and noticed it was getting easier to spin!
More and more turns later it seemed to loosen, stiffen, and loosen again until it was free wheeling as i would expect them to with barely any resistance.
I left it along for a bit, tried again later and it was stiff again. I repeated this and can say that if you leave the fan alone it stiffens up but loosens when you keep moving it.
I still dont think this is normal. Unless someone says differently I’ll be ordering a replacement fan, hopefully with a decent returns policy. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657843 26th Feb 2023 12:43pm
Phoenix
It shouldn't 'freewheel' - after all it has a viscous coupling so there will be some drag by design, where it is different is there is a PWM clutch involved to control the %age of lockup over that of the pure viscous coupling. The fan should rotate smoothly at any given temperature, with equal resistance, of course, the amount of resistance varies with temperature.
Why do you think there is a problem with it?
Post #657866 26th Feb 2023 5:36pm
Ffrr-lover
Good morning Phoenix.
The fan was removed while gaining access to the belt and pulleys, and when I removed it I noticed it was difficult to spin. Given the hassle with getting the fan out I would only put it back if sure it was ok.
As per my last post it is difficult to spin at first but eases up. It goes from turning just a few degrees at first and when I’ve managed to turn it a dozen times and it’s eased it’ll then begin to spin.
Maybe freewheel isn’t the best description as yes there is still resistance… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #657945 27th Feb 2023 8:19am
Phoenix
I must admit, it's not a test I've ever done, it does sound like the sort of behaviour I'd expect though. Do you have diagnostics capable of reading the fan speed and commanding it's lockup percentage? That would be the only way to reliably confirm correct operation that I know of.
Post #657987 27th Feb 2023 5:08pm
Baltic Blue
I remember going to the motor show with my brother in approx 1990 when the viscous transfer box was introduced to the Classic Range Rover. ( Not sure if the viscous fan came in at the same time, but it was included)
We stood watching a demonstration given by someone from the Lode Lane development department.
He had all sorts of bits in his demo including diffs and fans, but the most effective way he could describe how they work has stuck in my mind.
He had a large Pyrex mixing bowl full of hot water and a big wooden spoon.
No matter how hard he stired the bowl remained still.
He then added two heaped spoonfuls of baking powder to the water.
As soon as he started stirring the bowl started to turn.
The faster he stirred the more it spun and he finished by saying that’s how they work Rolling with laughter
Post #657991 27th Feb 2023 6:03pm
Phoenix
A 'non-Newtonian fluid' - probably corn starch not baking powder though.
Post #657996 27th Feb 2023 6:53pm
fisha
Re: Should the viscous fan spin freely when disconnected?
Stiff is normal. Should spin smooth, but with a smooth fiction feeling. Think like sliding a bag of flour across a worktop. It’ll slide with an even force, but as soon as you stop pushing, the bag will stop. The fan movement will be the same sort of movement. V8 or else ...
Post #658033 27th Feb 2023 11:21pm
Ffrr-lover
Good morning all.
No option to read diagnostics at this stage as the fan is out of the car.
however its a moot point as I have taken delivery of a new fan, and… it has the same behaviour!
So yes, to answer this fully… the viscous fan does turn with resistance which loosens the more you turn it.
Now to organise the return of the newly delivered fan… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #658142 1st Mar 2023 8:14am
p38arover
Australia
No, it’s true, not fictional. Smile Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #658143 1st Mar 2023 8:30am
fisha
I was just making it up … V8 or else ...
Post #658203 1st Mar 2023 8:26pm
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Isn't this the part that does the clicky clicky noise (mine does it - more so in winter) but when owners have changed them they start clicky as per usual a few weeks later?
Some simply say leave em... Rolling Eyes
Post #658260 2nd Mar 2023 3:47pm
