![]() | Home > Technical (L405) > ARB Drop link replacement - suspension knock |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
They're not critical enough to need replacing in pairs as they don't have any effect on alignment or ride height; but in practice I always do both on my cars as they're cheap and easy to replace and if one's gone the other's normally not far behind. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Bimshire Member Since: 23 Nov 2022 Location: Suffolk Posts: 18 ![]() ![]() |
Thanks, that was pretty much my thinking that I'd be back soon having the other side done. MY19 SDV8 Autobiography
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 239 ![]() ![]() ![]() |
I suggest replacing the sway bar bushings at the same time. The bushings are likely most of the issue. Replace both in pairs.
Thanks Bora that was my initial feel too but seeing as it's warranty work they have to get approval at every stage and this is all that's got the green light, if I was paying my independent I'd just do the whole lot. MY19 SDV8 Autobiography
