![]() | Home > Technical (L405) > Tailgate misbehaviour after installing new battery |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1593 ![]() ![]() ![]() |
Worth getting a good auto electrician to look at it, could be the tailgate control module gone awol, but it could equally be something else as simple as corrosion or a loose connection. No point in trying to guess.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Did it fail exactly when the battery was changed ?
3RangiesIn Member Since: 30 Nov 2022 Location: rm16 6ly Posts: 11 ![]() ![]() |
Hi it failed before the battery change. Gremlin 500- the connections are tight |
Sounds exactly the same as my issue |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1265 ![]() ![]() |
Do you have a cheap DTC scanner? example below, but check its OK for your MY and model etc
