Home > Maintenance & Mods (L322) > extended battery cables
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i put patch leads in today down the inner wing behind the washer bottle and out through the bumper vent blank on the
passenger side these will be used to energize the main battery if it discharges for any reason. i have fitted a second battery in the back but this comes in when it gets 12 volts from the main battery to put the 100 amp relay in when you turn on the ignition key
so this mod will come in when the main battery is flat and you need to get power to open the car etc . waiting for cable ends to come so I can finish the job . and also put a second 10mm earth cable from the body mount wear the battery is and fixed it to the earth mount on top of the front Strutt wear you are supposed to use your jumper leads earth
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #656518 13th Feb 2023 6:40pm
oggy
well, my connectors came last week so I will finish the job. i got a couple of Anderson connectors but was not working out as I hoped so I got a couple of welding cable extensions connectors and fitted so put the male ones on the battery side so you can clip your jump leads on when needed and then fit the female ones back on to seal the joints. i also cut the cables so they are staggered so the jump leaders won't touch each other. i have put an in-line fuse in place just in case. i put them in a waterproof bag and tucked them under the washer bottle and put the vent cover back on one more job out of the way
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657240 20th Feb 2023 4:41pm
What was the problem with Anderson connectors ?
I would have thought they were the best termination & what I have always used.
https://www.fullfatrr.com/forum/topic54284.html
Post #657295 21st Feb 2023 7:54am
oggy
hi alistair . okay if i fitted an Anderson in behind the vent then that would mean that the power pack or jumper battery would have to have the Anderson fitted as well to connect together and away you go. but that is okay if you are home or you have it in the car. that's if you can get in the car that is .if you are in the middle of no wear out for a walk etc and you get back to the car and the main battery has drained down that you can not even open the car you can not get to your power pack which is sat in the boot an Anderson connector would be no good. so you call out your breakdown service team that will come and put the jumper cables on my exposed fittings with a pair of jump leads. same as if you wear in asda car park there is always someone with a set of jump leads in the boot to help. because I have fitted a second battery in the boot means that I will not be starting the car from the front cables but only to energise the main battery so it will open the car .once the key is in the ignition then the relay will switch and bring in the second battery to start and the car will run off that one the cable ends are an easier way to connect on to most people have jump leads but not an Anderson fitting most people would not know what an Anderson is they would think it was a thing you built in the back garden when the war was on. new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657306 21st Feb 2023 9:56am
Good point Thumbs Up
As a last resort the connecters themselves can be released from the housing with a flat screwdriver, but I'd be very careful doing it with 2 equal length cables......
Post #657342 21st Feb 2023 3:28pm
dhallworth
I use the 13 pin towing socket on ours for this with the 13 pin C-Tek adapter purchased from the club shop.
Works great Smile
Post #657353 21st Feb 2023 4:38pm
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Defa charger. Just plug in 230V.
Every evening in, battery always full.
Plus cabin heater, activating together with Webasto.
Post #657526 23rd Feb 2023 8:15am
oggy
looking like a good set up jaguar 3 Thumbs Up new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657561 23rd Feb 2023 1:20pm
