Home > Technical (L322) > 4.4 TDV8 passenger footwell / battery box fan noise |
mxpUz6Q Member Since: 19 Sep 2022 Location: here Posts: 12 |
Hi,
13th Oct 2022 10:21am |
Hey colalowe,
14th Oct 2022 6:37pm |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
Hi Michael
18th Oct 2022 4:25pm |
Hi colalowe,
18th Oct 2022 8:42pm |
Hi Michael
19th Oct 2022 9:08am |
Hello colalowe,
19th Oct 2022 5:42pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
FBH will not fire up from the fob when engine idling. First what you can do just wait for outside temperature going under +5° and just start cold engine. Webasto should fire up automatically and continue working (if its not in lock mode due several unsucessiful starts). If its working then you can be sure that Webasto it self is ok. The problem in this case is or in circulation pump, or in HVAC. HVAC is very fussy and not let Webasto fire up from the fob for many reasons, for example too short distance traveled last time, too low battery, some own fault ect...and it just not give start permit via K-line and not inform you about this desigion anyhow.
20th Oct 2022 6:03am |
Hallo jaguar3,
21st Oct 2022 6:37pm |
Well, hard to say without hearing this noise. Some people wondering even with normal operating noise of FFBH. But its quite common problem with combustion fan, blower just touch the body during spinning and produce additional noise due that. And there is no fault codes with this issue due control module dont care about any noises when circuit is ok.
21st Oct 2022 6:57pm |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 |
mxpUz6Q in your video I can see, that yours is in venting mode not in heating mode, so the FBH is not activated (lower LED on AUTO-button blinking). It means that ambient temp is over 15C or at least ECU thinks so.
29th Nov 2022 8:11pm |
Hello kokamagi,
17th Feb 2023 7:05pm |
I found it easier to take K-bus signal from the connector C2242 in the passenger footwell. No need to unplug it (it is unplugged for other reasons in the picture), just back-probed the wire 50 (thin white-red) on the connector. Worked very well.
17th Feb 2023 8:12pm |
Hi kokamagi, jaguar3, colalowe,
18th Feb 2023 8:35pm |
Yes, you need to remove Webasto compleately, there is no space, so its impossible to do it without disconnecting the hoses and remove it compleatly. Its quite tedious work to get it back in place due limited space. Yes, there is normal hose clamps. Anyway you need to replace the gasket due this work, so its better to do when Webasto is on the table.
22nd Feb 2023 2:45pm |
