Home > In Car Electronics (L405) > Apple Car Play on 2017 model |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1423 |
Hi Jay, I have this on my MY2017 and it only works with a cable, but reliably.
14th Feb 2023 1:47pm |
Jay Porsche Member Since: 22 Jan 2023 Location: Solihull Posts: 59 |
Thanks Gremlin. Have tried all of those and still no joy, even cleaned the fluff out of my port and the car. Just need to try another phone to rule out mine being the problem. It has worked so it should be ok, cant figure it out. |
14th Feb 2023 3:54pm |
“ even cleaned the fluff out of my port and the car.”
14th Feb 2023 4:04pm |
memzy88 Member Since: 28 Jul 2017 Location: London Posts: 51 |
Mine works very reliably via the cable. Never had issue.
14th Feb 2023 4:25pm |
It works fine when I plug it in to charge, Sometimes have to wobble the cable.
14th Feb 2023 4:59pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 899 |
It will only work with a cable, even my 2021 MY has to be plugged in!
14th Feb 2023 6:32pm |
Thanks Chalky. Im all out of ideas now. So will try your suggestion.
15th Feb 2023 2:38pm |
Am I right in assuming you have the latest update on your iPhones (16.3)? If so then I would bet that the ACP in you car's Incontrol is not compatible. I'd call your dealer and ask for the latest update.
15th Feb 2023 2:59pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 768 |
I must say that, since the latest ICTP update (S22A_22.32.4-928505), the connection is much improved. I am using a Cplay2air wireless adapter and I would say it fails only once in 50-60 connections. In that case, only a system reboot (car closed for 10 minutes) reenables the CarPlay connection... Still, it's acceptable, given the crappy intel atom NUC (Next Unit of Computing) mini PC that strives to keep the infotainment alive... |
16th Feb 2023 2:12pm |
Thanks to all for your comments.
20th Feb 2023 8:46am |
All LR cars from 1984
20th Feb 2023 10:55am |
CSK942 Member Since: 02 Aug 2023 Location: South Somerset Posts: 7 |
Hi all,
9th Aug 2023 10:07am |
Plug your iPhone into the USB and if you have it, it will come up on the screen All LR cars from 1984
9th Aug 2023 10:15am |
Hi Chalky and thanks for that.
14th Aug 2023 9:17am |
