Home > Wheels & Tyres > Locking wheel nut key code |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
I had lost the locking wheel nut key on an earlier Range Rover - drove to the local dealer in Ashford, Kent. The parts chappie was able to determine the key number and was able to supply from stock - problem solved in minutes. 2012 4.4 TDV8 Vogue SE Current
24th Apr 2020 2:36pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
Ah the good old days when you could just drive to a dealer |
24th Apr 2020 4:03pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3783 |
Or even better, drop Dan an email and it would magically arrive at your door in days
24th Apr 2020 4:25pm |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 |
Thanks guys. The problem is the dealers are shut due to some sort of pandemic 🤔😒
24th Apr 2020 4:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
the letters a to z should be on the nut.. ... - .- -.
24th Apr 2020 4:47pm |
Have you tried logging on to Topix ?
24th Apr 2020 4:58pm |
So have you lost yours ?
24th Apr 2020 4:59pm |
Stan thanks I’ll check if I can see it in the wheel !
24th Apr 2020 5:00pm |
Open your boot - lift the spare wheel cover & have a look on the left side - under a carpet flap thingy
24th Apr 2020 5:03pm |
Topix is the Jaguar Land Rover database where dealers record all the service details for your car, but it includes lots of other information.
24th Apr 2020 5:20pm |
Would you believe it Alistair was right I’ve found it !!!!
24th Apr 2020 6:12pm |
You're not the first - I'm sure you won't be the last |
24th Apr 2020 6:19pm |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 293 |
He certainly wasn't the last
13th Feb 2023 11:45am |
