![]() | Home > Wheels & Tyres > Locking wheel nut key code |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
I had lost the locking wheel nut key on an earlier Range Rover - drove to the local dealer in Ashford, Kent. The parts chappie was able to determine the key number and was able to supply from stock - problem solved in minutes. 2012 4.4 TDV8 Vogue SE Current
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
Ah the good old days when you could just drive to a dealer |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Or even better, drop Dan an email and it would magically arrive at your door in days |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 ![]() ![]() ![]() |
Thanks guys. The problem is the dealers are shut due to some sort of pandemic 🤔😒
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
the letters a to z should be on the nut.. ... - .- -.
Have you tried logging on to Topix ?
So have you lost yours ?
Stan thanks I’ll check if I can see it in the wheel !
Open your boot - lift the spare wheel cover & have a look on the left side - under a carpet flap thingy
Topix is the Jaguar Land Rover database where dealers record all the service details for your car, but it includes lots of other information.
Would you believe it Alistair was right I’ve found it !!!!
You're not the first - I'm sure you won't be the last |
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
He certainly wasn't the last |
