![]() | Home > Technical (L405) > No start problem |
Check the engine control module for moisture on the connectors, the injectors not triggering indicate a fundamental issue, not a problem with the injectors themselves. Are the crank & camshaft position sensors connected and giving an output? There isn't an injector 'fuse' as such, but there are several power supplies to the control module, along with several ground connections. you need to check these using the appropriate wiring diagram. |
FR motors Member Since: 16 Dec 2022 Location: Graz Posts: 13 ![]() ![]() ![]() |
Thank you for your Quick replay.... I cant find any wiring diagram for that car maybe you can point me Somewhere? (link).
Can't help with the wiring diagam but you can buy a day's access to Topix for a single VIN quite cheaply, and spend the 24hrs downloading everything for that vehicle you could possibly need...
So I maniged to clear code p060a But now i get code U0447-00(getaway module A invalid data recived) and still no pressure after injector pump.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8384 ![]() ![]() ![]() |
This any help, but I think you may need a good auto electrician... |
Can secondary battery giving me trouble for starting the car? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35507 ![]() ![]() |
no, but check that the primary battery is ok. ... - .- -.
PriMary battery IS New also took ecu out for 1h
Look at actual values for fuel pressure (high & low), crank & camshaft sensors and MAF/ Charge air sensors, both static and cranking, they should give you a better idea of what is happening - or not, with your failure to start issue. |
Ok I Got rid of u0447-00 it was second battery. Now car cranks much better But now i have code P062E-11 fuel injector driver circuit performance bank 2.
So I Got someone with high end tester to my range
Test all the injectors & wiring as per the following, pay particular attention to the harness being shorted to ground or mutual shorts.
