Home > Technical (L405) > No start problem |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Check the engine control module for moisture on the connectors, the injectors not triggering indicate a fundamental issue, not a problem with the injectors themselves. Are the crank & camshaft position sensors connected and giving an output? There isn't an injector 'fuse' as such, but there are several power supplies to the control module, along with several ground connections. you need to check these using the appropriate wiring diagram. |
11th Feb 2023 6:21pm |
FR motors Member Since: 16 Dec 2022 Location: Graz Posts: 13 |
Thank you for your Quick replay.... I cant find any wiring diagram for that car maybe you can point me Somewhere? (link).
11th Feb 2023 6:41pm |
Can't help with the wiring diagam but you can buy a day's access to Topix for a single VIN quite cheaply, and spend the 24hrs downloading everything for that vehicle you could possibly need...
11th Feb 2023 7:35pm |
So I maniged to clear code p060a But now i get code U0447-00(getaway module A invalid data recived) and still no pressure after injector pump.
13th Feb 2023 9:44am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8274 |
This any help, but I think you may need a good auto electrician...
13th Feb 2023 12:03pm |
Can secondary battery giving me trouble for starting the car? |
13th Feb 2023 12:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
no, but check that the primary battery is ok. ... - .- -.
13th Feb 2023 12:26pm |
PriMary battery IS New also took ecu out for 1h
13th Feb 2023 12:31pm |
Look at actual values for fuel pressure (high & low), crank & camshaft sensors and MAF/ Charge air sensors, both static and cranking, they should give you a better idea of what is happening - or not, with your failure to start issue. |
13th Feb 2023 3:34pm |
Ok I Got rid of u0447-00 it was second battery. Now car cranks much better But now i have code P062E-11 fuel injector driver circuit performance bank 2.
14th Feb 2023 10:13am |
So I Got someone with high end tester to my range
14th Feb 2023 2:03pm |
Test all the injectors & wiring as per the following, pay particular attention to the harness being shorted to ground or mutual shorts.
14th Feb 2023 6:15pm |
