![]() | Home > In Car Electronics (L322) > L322 2007 Android Headunit Options |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
a few tips for the next installer
[/img] Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
KZ Member Since: 19 Jan 2023 Location: Victoria Posts: 15 ![]() ![]() ![]() |
Hey mgrover I am planning to purchase the same head unit as you installed and was hoping that I could trouble you for some more info about it.
I can check that next time I am in the car. I know which ones your on about but this is 12.3 i think because it gets rid of the bezels.
Setting the clock works fine, both the dash clock and the analogue one. There is no 4x4 info at all. There are other "car" settings, like mpg, rpm, temp etc etc, and some settings like C/F your supposed to be able to change. but they don't change at all. One thing that doesn't work is remapping the setting wheel controls. I want one button to be set as the BACK button, but havent made it work via their app.
Yes, I installed Nova launcher, not a fan of their launcher.
Sure. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 163 ![]() ![]() ![]() |
Yep, they mirror the android unit. Happy to try to make a vid.
and this is really good information 😀 |
Thanks for the info.
I am guessing the 4x4 info and other settings can still be accessed and adjusted via the dash gauge display anyhow. Hopefully that didn't change.
The steering wheel controls operate but can't be changed? If so I have a similar setup in my jeep and it doesn't respond to the system software. I believe the module that enables the steering wheel controls may be hard coded . I always meant to see if there was a steering wheel control adapter which could be added to enable both short and long press programming of the buttons. A few other things I thought I should ask: How is the phone call clarity? Does the head deck retain the trim pieces to the left and right of the display? or would one need to paint the sides of the adapter black? (in my case the trim is piano black) Thanks mgrover! PS just watched the video excellent....the head deck looks like a good bet to me. Last edited by KZ on 8th Mar 2023 11:34am. Edited 1 time in total |
Yes via the dash is fine, when you put it in offroad mode or whatever you can enable that mode where the dash changes to off road mode.
For me it's good, I installed the mic on the steering wheel, which btw is 2.5mm and the head unit port is 3.5mm so you need an adapter. Or am I remembering my BMW cause I did both very close together.
No it doesn't, I have a similar problem, they need to be painted piano black. I opted to just leave it tbf, laziness and all. One thing I did notice is there is the amp hum. Now you can tweak the little device ground it comes with to try and negate that but you can still hear it, but once the car is started you never notice it tbh. Its actually a sport ![]() Not anymore, 4.4 TDV8 now ![]() |
Urotex Member Since: 16 Nov 2014 Location: TX Posts: 21 ![]() ![]() ![]() |
https://www.aliexpress.us/item/32568047746...DDNiEXyCbS
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 80 ![]() ![]() ![]() |
That is an interesting piece of kit; I've already added Android Auto/Carplay into my 2010 but this intrigues me! |
maybe some day. when they add support for original screens and change graphics to corrected l322 |
Here's one with the FFRR |
but still wrong one... |
