Home > In Car Electronics (L322) > L322 2007 Android Headunit Options
Page 3 of 5 <12345>
Googs
Australia
yes Vogue.
Ah yes I've seen these 5m cables on different sites as I've been searching the internet....do you mean this way is plug & play?
The audio system i have or should i say the speaker system is ok, so the 5m cable idea would work great as long as i didn't have to cut any of the original wiring loam, as i said i would only have to splice in the reverse camera.
Thx for the link to the head unit that gives me another avenue to get some sound in the RR.
Post #641697 1st Sep 2022 7:51pm
Danwilderspin
Yea the only wire cutting you’d need to do would be to the speakers if you were bypassing the dsp amp Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #641732 1st Sep 2022 11:33pm
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
I’ve just installed a Navtool box in my L322 and it’s amazing. All fits in the back by the sat nav so n messing about with the dash. Retails access to all factory things like 4x4 and radio etc but adds CarPlay and Android Auto. Takes about half an hour to fit and the hardest part is getting the aux cable through from the back of the car.
 Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #641741 2nd Sep 2022 7:58am
Googs
Australia
I have one of those nav's but without an amp it is useless, if i can find a DSP Amp i could connect and do much the same.
Does it have DAB radio?
Post #641836 2nd Sep 2022 7:59pm
tymh
No. It is literally a CarPlay/android auto unit Tym
Post #641837 2nd Sep 2022 8:03pm
tymh
You can use the countless apps on your phone to listen to whatever station takes your fancy. Tym
Post #641851 2nd Sep 2022 10:25pm
Rjh112
My icebox audio unit will be available if anyone is interested in making me an offer, brand new in box never fitted, the l322 is going shortly to be replaced with a BMW X6M. Give me a DM/PM, mods if this needs deleted I understand
Post #642292 7th Sep 2022 5:23pm
mdis89
Ah gutted that you never got to install the unit!
@Danwilderspin - It has some terrain response-ish looking area, but im fairly sure its broken (should show the wheel alignment, but they eventually just creep off the screen).
Those 2 other new units you posted look really nice! - Id have been tempted with the larger screen version, if id not already got my current one.
Post #645252 10th Oct 2022 10:32am
mgrover
Morning gents.
Am trying to understand.
With the icebox unit
Does the amp continue to function? I know I might lose fading and what not but does the amp itself continue to work?
Do the steering wheel controls work?
Does the setting of clock/date work for the speedo dash?
I know for the RRS I had to get a MOST decoder to rca for the amp. Is that the same here?
Am told there's also audio head unit. Is that what allows us to avoid the decoder?
Cheers Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #651586 24th Dec 2022 10:13am
mdis89
The icebox one I had linked to, there's no extra long wires to fit, and as far as I can see all the original amp, steering wheel controls etc all work fine.
Clock can be set on the unit, which updates the clock on the dash.
The only setting that doesn't work (for me anyway), is that all the distances on the speedo are in kmh, not mph (setting exists on the amp to change it but doesn't update).
Original reverse camera also works completely fine in this unit.
Post #651587 24th Dec 2022 10:19am
mgrover
Ah perfect thanks.
That sounds great. Worth every penny imo.
I wonder if I change the km to mph via the gap tool
Ah realised your probably not far from me.
Did you order from the alieexpress link or the guys in Liverpool?
Also is it the qualcomm cpu? Its actually a sport Sad
Post #651588 24th Dec 2022 10:24am
mdis89
Ah I've not used the gap tool before, if it works let me know!
It's only a minor annoyance for me, and can ignore it, but would be nice if it was in mph.
Got it direct from the icebox guys - they only really order from their supplier (probably aliexpress ha) once you've done an order, so delivery is just as long, but I guess they're also happy to answer questions if your installing it yourself too.
All the details should be correct whats on the icebox listing, but I'll have a look at the specs on my unit later today
Post #651589 24th Dec 2022 10:33am
mgrover
i noticed in the post
https://www.fullfatrr.com/forum/topic64874.html
you can see in the 5th pic, main scale units and set them there. i havent registered my gap tool yet with this car. Its actually a sport Sad
Post #651689 26th Dec 2022 9:25pm
mgrover
am going to pull the trigger on this one
https://www.iceboxauto.com/range-rover-vog...lay-dab-bt
a bit bigger than the standard 10inch. we'll see how it goes. Its actually a sport Sad
Post #654120 20th Jan 2023 10:53am
mgrover
i was wondering, am about to install the sucker, i plugged the fibre optic to the one that came behind the old head unit and the power cable to the one behind the glove box.
but ive got no sound or steering controls. am guessing the fibre optic loop is broken.
did you use the loop back cables anywhere?
cheers Its actually a sport Sad
Post #656068 8th Feb 2023 7:49pm
Page 3 of 5 <12345>
