Home > Technical (L322) > what goes here???
joninprague
what goes here???
Morning all,
So I have recently bought a tdv6 3.0 and did the normal look at the engine like I am supposed to know what I am looking for but everything looked perfect and the car runs without any problems. However on getting a start cleaning the car I noticed these tucked away. assume 1 is to do with fuel but no idea where it should connect as there are no places for it to go and also the electrical connectors that where tucked away too.
I have tried to google some pictures of the engine bay to try and figure it out but nothing really helped!!
Please help!! Shocked
Post #655817 6th Feb 2023 11:19am
mjdronfield
Nothing, pretty sure it’s for the fuel heater that’s not fitted in the UK…. Slide it out the way.
Sold mine years ago so can’t double check.
It’s not a V6, it’s an inline 6, so a TD6 not a TDV6.
Hope you enjoy it. Mine was very reliable when I had one.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #655821 6th Feb 2023 12:29pm
joninprague
Thanks so much does sound like it might have been, Just strange to have a fuel filter connected to a pipe that doesn't connect to anywhere?
thanks again for your help
Jon
Post #655825 6th Feb 2023 1:54pm
mjdronfield
I’m sure someone with a TD6 they can check will let us know for sure, but I know I had unused cables there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #655827 6th Feb 2023 2:31pm
Merchy
Mine is exactly the same. As said above, secure it to the side, and forget about it.
Post #655832 6th Feb 2023 4:24pm
joninprague
I will do just that Smile
Thanks again for your help. very much appreciated
Post #655888 7th Feb 2023 9:07am
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
I may be wrong, but I think it could be the transmission or front diff breather. In which case it shouldn’t have a cap on the end of it.
Post #655915 7th Feb 2023 11:57am
stuart_2006
The little filter is an air vent for turbo actuator vacuum system. Shouldn't have anything on the end of it.
Post #655962 7th Feb 2023 7:26pm
joninprague
Thanks for that so should i just remover the fuel filter looking thing so the pipe has nothing on the end and then just tuck them away?
I really appreciate the help
Jon
Post #655963 7th Feb 2023 7:42pm
stuart_2006
Nope, the filter should be there on the end of the pipe to stop small animals being sucked in. But looking at your photo it looks like the top connection on the filter has a bit of black pipe on it and may be blocked off? Shouldn't be anything on the top connection of the filter.
Post #655965 7th Feb 2023 7:55pm
joninprague
Perfect I will take the pipe off the top.
Cheers
Jon
Post #655967 7th Feb 2023 8:24pm
